Feature Requests
Set the name for any NDI output
Currently (v 20.0.0.30) the names for the NDI sources are automatically defined by vMix, for example: vMix - Output 2 Audio Digital Audio Interface
To be able for easier NDI source identification, in particular when multiple vMix are on the NDI network, it would be useful if the operator could set the names.
One approach would be to offer a checkmark "Use Input name" for each NDI source in the Settings->Output/NDI tab. Another one to have a field next to each item on that tab.
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
Joined: 10/8/2013(UTC) Posts: 45  Thanks: 4 times Was thanked: 6 time(s) in 5 post(s)
Joined: 11/8/2013(UTC) Posts: 87  Location: Bavaria, Germany Thanks: 6 times Was thanked: 19 time(s) in 10 post(s)
Joined: 12/27/2012(UTC) Posts: 5,527  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
Joined: 2/14/2020(UTC) Posts: 29  Location: Brisbane Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Joined: 9/22/2020(UTC) Posts: 45  Thanks: 3 times Was thanked: 5 time(s) in 5 post(s)
+1
v24 and this is still not available ... We need to be able to give/change the name of the 4 NDI video output & also having the name of the Audio Bus (now that we can name them) showing up on the audio only NDI feed imho.
Help putting this at the top of the list quick reply +1 !
Rank:: Newbie
Joined: 9/20/2024(UTC) Posts: 7  Thanks: 10 times Was thanked: 2 time(s) in 2 post(s)
Joined: 9/30/2024(UTC) Posts: 12  Location: Cayenne Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
Rank:: Advanced Member
Joined: 11/14/2012(UTC) Posts: 361  Location: Finland Thanks: 232 times Was thanked: 24 time(s) in 22 post(s)
Joined: 12/14/2018(UTC) Posts: 161   Location: Clermont-Ferrand Thanks: 36 times Was thanked: 9 time(s) in 8 post(s)
Just to inform you I've created an app for renaming NDI outputs. Originally Posted by: sadmb  https://github.com/anno-...puts/releases/tag/v1.0.1It's basically similar as the official NDI router app. But more simple for renaming purpose. 1. press "add router" button. 2. select one of the NDI outputs. 3. name it. (4. press save button to resume after restarting the app.) So you can change the name of any NDI outputs. Note it doesn't resume when no source exists with the same name as you saved. Means you have to open this app after vMix when you want to restart. I hope this feature will be implemented in the near future. :) For people who really need this function, enjoy.
Feature Requests
