voyagermix
#1 Posted : Wednesday, December 4, 2019 12:09:28 PM(UTC)
voyagermix
Mexico
I have an .HTML file with more than 200 people, the VMIX takes more than three minutes to load that file, as they are runners and they reach the goal I need it to be updated every 20 seconds, but it will take another 3-5 minutes because it Vmix weighs that database so much and how to fix it?
My LAPTOP:
Dell Alienware 17 R3 6th Gen I7-6820hk 4.1ghz/16gb/
Video 4GB NVIDIA® GeForce® GTX 980M
#2 Posted : Wednesday, December 4, 2019 2:44:44 PM(UTC)
Was thanked: 4739 time(s) in 1626 post(s)
How are you loading the file into vMix?
Note that Data Sources does not support HTML.
voyagermix
#3 Posted : Friday, December 6, 2019 5:08:15 AM(UTC)
voyagermix
Mexico
Still the same thing happens with a .CVS file
#4 Posted : Friday, December 6, 2019 5:15:16 AM(UTC)
Where are you getting the file from ? locally , online ....
Maybe care to show (part of) mentioned file ?
voyagermix
#5 Posted : Friday, December 6, 2019 6:50:53 AM(UTC)
voyagermix
Mexico
at first on an internal network and we thought that was the problem, but the same on the local hard drive
voyagermix
#6 Posted : Sunday, December 8, 2019 3:15:57 AM(UTC)
voyagermix
Mexico
any solution? 21.0.0.61
#7 Posted : Sunday, December 8, 2019 3:24:46 AM(UTC)
Maybe.... if you give more information
Is it with this file only or all files?
How big is the file?
Already asked: care to share part or all of the file ? (so others can check)
What license ?
What ever that might help to find out
TBacker
#8 Posted : Monday, December 9, 2019 10:34:53 AM(UTC)
TBacker
We had a problem with XLS / XLSM files loading slowly and causing the GUI to hang. In our case it was vMix Data Source loading every single column in the spreadsheet - even empty ones. It turned out that any kind of formatting applied to a cell (like text alignment, word wrap, etc.) had caused vMix to treat it as having data in it even if the cell was empty.
Not sure what source you're using, but once it loads into vMix, check to see if there are a ton of empty rows and/or columns that it's processing.
