Feature Requests
Title Presets: Save data source assignment in preset
Joined: 10/29/2019(UTC) Posts: 105  Location: Syracuse Thanks: 11 times Was thanked: 5 time(s) in 4 post(s)
It appears that data sources assigned to a title field are global for that title and do not follow / store with presets.
We have a data source per show for a lower third, and were hoping to just change presets per show. But the data source assigned does not change with the preset.
I do a monthly show and use the same folder/name for the data sources. For the next show I just overwrite the datasource files and don't need to worry.
We do several shows a day, each with a different rotation on this title, and thus a different source list.
These shows are run by operators with varying capability and sometimes not the best attention to detail. So, overwriting a file is fraught with a bit of danger.
For now, we will be changing to a single data source and switch it to different source sheets for each show. Not optimal, several clicks to do, but as simple as I can come up with at the moment.
Originally Posted by: TBacker  It appears that data sources assigned to a title field are global for that title and do not follow / store with presets.
We have a data source per show for a lower third, and were hoping to just change presets per show. But the data source assigned does not change with the preset. Could you please explain what assignments are not retained when you open a preset with datasource(s). It seems to work for me...
Originally Posted by: richardgatarski  Could you please explain what assignments are not retained when you open a preset with datasource(s). It seems to work for me... I have a lower third title with an image box that rotates, the image list changing per show. If I create a data source for each list / show, and attempt to make a set of presets for that title that change the data source which feeds the image box, it doesn't work - the last selected data source stays tied to the box no matter which preset is selected. I'm talking about TITLE presets, not vMix setup presets.
Feature Requests
