9 Pages«<56789>
#121 Posted : Tuesday, November 19, 2019 6:10:24 PM(UTC)
Was thanked: 4708 time(s) in 1613 post(s)
We will be adding Stream ID support in the next update.
claudiogp65
#122 Posted : Wednesday, November 20, 2019 8:33:40 AM(UTC)
claudiogp65
Argentina
Hi, I have this problem, I upload a video and in the Preview Window the video looks a few seconds and then turns black, the audio is heard but nothing is seen. Any solution?
Sorry for my English
#123 Posted : Wednesday, November 20, 2019 11:59:21 AM(UTC)
Please email us at info@vmix.com.au and upload the video so we can test.
AndrewRed
#124 Posted : Thursday, November 21, 2019 6:57:29 AM(UTC)
AndrewRed
Originally Posted by: admin Go to Quoted Post
Hi Andrew,
We have not made any controller changes in vMix 22, so there must be something about a new 23 feature
that is causing the iCON driver to fail.
Are you using any of the new features? Are your settings or presets different between versions?
I would suggest sending a support report and dropping us an email.
We will send a support report via email. Yes we're using the multiple audio buses, all of them. As well as all the calls for the pro version. Each with an out of state call in all on their own bus. So maybe something there. We'll email and get it figured out. Thanks again!
#125 Posted : Thursday, November 21, 2019 3:16:51 PM(UTC)
23.0.0.24
http://cdn.vmix.com/download/vmix23preview.exe
* Updated NDI to latest 4.1.3 official release.
* Added support for alpha channel in NDI MOV files
* Increased SRT latency support to up to 30,000 ms (30 seconds)
* Added support for SRT Stream ID when using Caller
* Added option to display Stinger transition underneath other Overlays through check box in Overlay settings.
* Fixed trigger function ActiveInput/PreviewInput selecting wrong input when moving inputs around.
* Fixed Replay colour correction issue when source input changes or resets in the middle of session.
* Added support for LT, Standard and HQ MOV quality in vMix Media Converter
* Added ability to select different destination folder in vMix Media Converter
thanks 7 users thanked admin for this useful post.
sinc747 on 11/21/2019(UTC), avsoundguy on 11/21/2019(UTC), stevespaw on 11/22/2019(UTC), doggy on 11/22/2019(UTC), BETech on 11/22/2019(UTC), raugert on 11/22/2019(UTC), stigaard on 11/22/2019(UTC)
dark_ata
#126 Posted : Friday, November 22, 2019 12:53:23 AM(UTC)
dark_ata
Was thanked: 18 time(s) in 13 post(s)
i´m trying srt vmix to vmix, and when put hevc said "error requested coded is not installed on this pc: hevc "
#127 Posted : Friday, November 22, 2019 1:07:18 AM(UTC)
Per the documentation:
"When using HEVC on Windows 10, the "HEVC Video Extensions" from the Microsoft Store is required to be installed."
monamiga
#128 Posted : Saturday, November 23, 2019 12:08:17 PM(UTC)
monamiga
Philippines
In GT Designer 2.0.0.23 font shrink when mid level selected. Upper & lower level were okay ("shrink" mode in text box resizing). All were okay in previous version of GT Designer.
e.belyshev
#129 Posted : Saturday, November 23, 2019 2:29:42 PM(UTC)
e.belyshev
So looks like all the owners of vMix HD v22 will loose a very important feature if they decide to switch to vMix HD v23 is the ability to send the mix to external outputs?
MycroBeat99
#130 Posted : Sunday, November 24, 2019 5:07:28 AM(UTC)
MycroBeat99
Romania
Same for me.
thanks 1 user thanked MycroBeat99 for this useful post.
monamiga on 11/24/2019(UTC)
#131 Posted : Sunday, November 24, 2019 12:50:11 PM(UTC)
Can you clarify what you are referring to? This is most definitely still in 23 and has not changed from 22?
#132 Posted : Sunday, November 24, 2019 12:51:56 PM(UTC)
Same for me.
Can you describe step by step on how to replicate this as I am not seeing any issues.
monamiga
#133 Posted : Sunday, November 24, 2019 3:39:08 PM(UTC)
monamiga
Philippines
Sample GTZIP file SHRINK.gtzip (24kb) downloaded 9 time(s).
#134 Posted : Sunday, November 24, 2019 4:56:30 PM(UTC)
Thanks,
This is actually a fix in 23, as the shrinking in 22 did not take into account certain fonts which would get cut off in some cases.
So the new sizing is now more accurate.
EDIT: I think this can be improved a bit in the next update, but still not exactly the same as 22 due to the improvements noted above.
MycroBeat99
#135 Posted : Monday, November 25, 2019 4:57:43 AM(UTC)
MycroBeat99
Romania
Hi. This video maybe it will help you. Look at the Text, level of text and the GT version. The Text are much smaller in the GT .23 then .18. If you use small vertical height, the difference is considerable.
https://www.youtube.com/watch?v=Sk3Vwsj8EVI
sam602
#136 Posted : Tuesday, November 26, 2019 7:05:09 AM(UTC)
sam602
Trinidad And Tobago
Custom RTMP streams that are interlace seem to have lines on the output with ver 23. I was using 1080 59.94i and notice it
stevespaw
#137 Posted : Tuesday, November 26, 2019 8:12:01 AM(UTC)
stevespaw
Was thanked: 76 time(s) in 57 post(s)
Are there API commands for the new "mix" input by chance yet?
I see here https://www.vmix.com/help23/index.htm?Mix.html
a reference to it, but could we get an example? i.e.
http://127.0.0.1:8088/api/?Function=Fade&Duration=1000
Thanks a lot!
Steve
#138 Posted : Tuesday, November 26, 2019 12:38:00 PM(UTC)
Streaming providers do not support interlaced, so turn that off in Settings -> External Output by ticking "Use Streaming Settings"
raugert
#139 Posted : Tuesday, November 26, 2019 1:17:17 PM(UTC)
raugert
Canada
Was thanked: 322 time(s) in 184 post(s)
@stevespaw
The API commands for "Mix" inputs:
http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Mix=0 (vMIx Main)
http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Mix=1 (Mix 2)
http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Mix=2 (Mix 3)
http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Mix=3 (Mix 4)
The Mix index in the API starts at "0" which is a little different than in the shortcut settings (Mix1-4).
Richard
thanks 1 user thanked raugert for this useful post.
stevespaw on 11/26/2019(UTC)
e.belyshev
#140 Posted : Wednesday, November 27, 2019 5:27:30 AM(UTC)
e.belyshev
I just purchased vMix HD few month ago based on the features that were listed in this comparison chart:
https://www.vmix.com/purchase/
But now when v23 came out this chart got updated and removed option "Two External Outputs" from HD version.
Guest (12)
9 Pages«<56789>
