Joined: 1/13/2010(UTC) Posts: 5,326  Location: Gold Coast, Australia Was thanked: 4733 time(s) in 1623 post(s)
We will be adding Stream ID support in the next update.
Joined: 11/20/2019(UTC) Posts: 2  Location: buenos aires
Hi, I have this problem, I upload a video and in the Preview Window the video looks a few seconds and then turns black, the audio is heard but nothing is seen. Any solution? Sorry for my English
Originally Posted by: admin  Hi Andrew,
We have not made any controller changes in vMix 22, so there must be something about a new 23 feature that is causing the iCON driver to fail.
Are you using any of the new features? Are your settings or presets different between versions?
I would suggest sending a support report and dropping us an email.
Martin vMix We will send a support report via email. Yes we're using the multiple audio buses, all of them. As well as all the calls for the pro version. Each with an out of state call in all on their own bus. So maybe something there. We'll email and get it figured out. Thanks again!
23.0.0.24http://cdn.vmix.com/download/vmix23preview.exe* Updated NDI to latest 4.1.3 official release. * Added support for alpha channel in NDI MOV files * Increased SRT latency support to up to 30,000 ms (30 seconds) * Added support for SRT Stream ID when using Caller * Added option to display Stinger transition underneath other Overlays through check box in Overlay settings. * Fixed trigger function ActiveInput/PreviewInput selecting wrong input when moving inputs around. * Fixed Replay colour correction issue when source input changes or resets in the middle of session. * Added support for LT, Standard and HQ MOV quality in vMix Media Converter * Added ability to select different destination folder in vMix Media Converter
 7 users thanked admin for this useful post.
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
i´m trying srt vmix to vmix, and when put hevc said "error requested coded is not installed on this pc: hevc "
Per the documentation: "When using HEVC on Windows 10, the "HEVC Video Extensions" from the Microsoft Store is required to be installed."
Joined: 5/20/2017(UTC) Posts: 63   Location: Philippines Thanks: 171 times Was thanked: 3 time(s) in 2 post(s)
In GT Designer 2.0.0.23 font shrink when mid level selected. Upper & lower level were okay ("shrink" mode in text box resizing). All were okay in previous version of GT Designer.
So looks like all the owners of vMix HD v22 will loose a very important feature if they decide to switch to vMix HD v23 is the ability to send the mix to external outputs?
Joined: 8/31/2015(UTC) Posts: 31   Location: Romania Thanks: 12 times Was thanked: 2 time(s) in 2 post(s)
Originally Posted by: monamiga  In GT Designer 2.0.0.23 font shrink when mid level selected. Upper & lower level were okay ("shrink" mode in text box resizing). All were okay in previous version of GT Designer. Same for me.
 1 user thanked MycroBeat99 for this useful post.
Originally Posted by: e.belyshev  So looks like all the owners of vMix HD v22 will loose a very important feature if they decide to switch to vMix HD v23 is the ability to send the mix to external outputs? Can you clarify what you are referring to? This is most definitely still in 23 and has not changed from 22?
Originally Posted by: MycroBeat99  Originally Posted by: monamiga  In GT Designer 2.0.0.23 font shrink when mid level selected. Upper & lower level were okay ("shrink" mode in text box resizing). All were okay in previous version of GT Designer. Same for me. Hi, Can you describe step by step on how to replicate this as I am not seeing any issues. Regards, Martin vMix
Sample GTZIP file  SHRINK.gtzip (24kb) downloaded 9 time(s).
Thanks,
This is actually a fix in 23, as the shrinking in 22 did not take into account certain fonts which would get cut off in some cases. So the new sizing is now more accurate.
EDIT: I think this can be improved a bit in the next update, but still not exactly the same as 22 due to the improvements noted above.
Martin vMix
Hi. This video maybe it will help you. Look at the Text, level of text and the GT version. The Text are much smaller in the GT .23 then .18. If you use small vertical height, the difference is considerable. https://www.youtube.com/watch?v=Sk3Vwsj8EVI
Joined: 5/8/2019(UTC) Posts: 37  Location: Port of Spain Thanks: 14 times Was thanked: 1 time(s) in 1 post(s)
Custom RTMP streams that are interlace seem to have lines on the output with ver 23. I was using 1080 59.94i and notice it
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
Originally Posted by: sam602  Custom RTMP streams that are interlace seem to have lines on the output with ver 23. I was using 1080 59.94i and notice it Streaming providers do not support interlaced, so turn that off in Settings -> External Output by ticking "Use Streaming Settings"
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
@stevespaw The API commands for "Mix" inputs: http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Mix=0 (vMIx Main) http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Mix=1 (Mix 2) http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Mix=2 (Mix 3) http://127.0.0.1:8088/api/?Function=Fade&Duration=1000&Mix=3 (Mix 4) The Mix index in the API starts at "0" which is a little different than in the shortcut settings (Mix1-4). Richard
 1 user thanked raugert for this useful post.
Originally Posted by: admin  Originally Posted by: e.belyshev  So looks like all the owners of vMix HD v22 will loose a very important feature if they decide to switch to vMix HD v23 is the ability to send the mix to external outputs? Can you clarify what you are referring to? This is most definitely still in 23 and has not changed from 22? I just purchased vMix HD few month ago based on the features that were listed in this comparison chart: https://www.vmix.com/purchase/But now when v23 came out this chart got updated and removed option "Two External Outputs" from HD version.
