Feature Requests
Allow scripts to be called in playlist
Joined: 5/6/2016(UTC) Posts: 83  Was thanked: 5 time(s) in 5 post(s)
The following would be VERY helpful to us, as one of our vMix licenses we use as a playout machine for a 24-hour channel.
The ability to execute a script in a playlist would be very helpful. For instance, the ability to add a script into a playlist position before two videos.
The following scenario would be our holy-grail...
Playlist:
1) Video Segment 1 2) -script- (triggers something to happen externally via CURL. In this case, tells our server-side ad insertion to splice ads into the final HLS stream) 3) Video slate (2 minutes of filler - the length of our ad break) 4) Video Segment 2
and so on and so forth.
If there's another way to do this, let me know...I haven't found a way. I can get halfway there with triggers on events, but the above would be far superior.
Thanks!
Quote:the ability to add a script into a playlist position before two videos. Change before to after ;-) trigger a script with oncompletion or ontransitionout in Video Segment 1
Feature Requests
