Joined: 8/25/2018(UTC) Posts: 23   Location: Da OC, CA Was thanked: 1 time(s) in 1 post(s)
Hey Everyone,
I've been using the BMD DeckLink 8K Pro for a while now. 99% of the time it works great.
However, every once in a while all the inputs will just lockup. The only way to restore them is a full PC reboot.
Is anyone else experiencing anything like this with their 8K Pros?
Thanks,
-Jerry
Joined: 12/4/2019(UTC) Posts: 3  Location: California Was thanked: 2 time(s) in 2 post(s)
Hi Johnny, Can you tell me about your hardware? I had a similar problem. I was able to fix it.
Joined: 5/15/2011(UTC) Posts: 36  Location: south Korea Thanks: 3 times Was thanked: 1 time(s) in 1 post(s)
Hi, everyone. I have a similar phenomenon to you. Normal operation when system re-booting. CPU: AMD Risen7 3700X. M/B: GIGABYTE X570 AORUS PRO VGA: GTX1660 RAM: 32GB SSD:500GB HDD:1TB O/S: WIN10-pro Capture: Decklink 8Kpro / Intensity-pro thanks. julian lee.
Joined: 4/28/2017(UTC) Posts: 3 Location: Philadelphia
I also have this problem. Any suggestions for a fix?
i9 9900x ASRock X299 OC FORMULA GIGABYTE RTX 2080 Ti Samsung 970 EVO 1TB Seasonic 850w 32GB DRAM 3200MH Win 10 pro Decklink 8K Pro
