BartekDziedzic
#1 Posted : Tuesday, November 12, 2019 12:55:07 AM(UTC)
BartekDziedzic
Poland
Hello
I'm trying to configure Behringer X-touch Compact midi controller to work with vmix- could someone share some template for shortcuts and activators?
I have problem with configurating Faders to work as a master volume control, or T-bar. Also I can't setup Encoders Rings to work with some activators.
Thanks!
For example: when I make activator which changes master Volume: When I use Software master volume control it changes assigned fader (or encoder ring) but if I want change Master volume from midi controller Vmix doesn't react (I move Fader, and few seconds later it goes to position as it is in Vmix software)
Ok I have solution but next problem.
I made a shortcut instead of activator And now Midi controller changes value on vmix but every time i make adjustment with fader it goes to 0-neutral position and want show real value as it is in Vmix.
If somebody have solution I will be thankfull for help.
Peter1000
#2 Posted : Tuesday, November 12, 2019 3:55:38 AM(UTC)
Peter1000
Switzerland
Was thanked: 84 time(s) in 64 post(s)
this are the activators and shortcuts for behringer xtouch mini
Behringer Xtouch Mini
btw. a 1 minute google search......
first hit: type the following in google search: youtube behringer xtouch midi VMIX
