Hardware Compatibility
Behringer x-touch compact templates for midi controler
Hello I'm trying to configure Behringer X-touch Compact midi controller to work with vmix- could someone share some template for shortcuts and activators? I have problem with configurating Faders to work as a master volume control, or T-bar. Also I can't setup Encoders Rings to work with some activators. Thanks!
For example: when I make activator which changes master Volume: When I use Software master volume control it changes assigned fader (or encoder ring) but if I want change Master volume from midi controller Vmix doesn't react (I move Fader, and few seconds later it goes to position as it is in Vmix software) Ok I have solution but next problem. I made a shortcut instead of activator And now Midi controller changes value on vmix but every time i make adjustment with fader it goes to 0-neutral position and want show real value as it is in Vmix. If somebody have solution I will be thankfull for help.
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
