millst
#1 Posted : Monday, November 11, 2019 8:02:32 AM(UTC)
millst
Was thanked: 7 time(s) in 3 post(s)
When you call...
http://127.0.0.1:8088/API/?Function=ActiveInput&Input=2
It doesn't fire the trigger (OnTransitionIn) for that input.
I'm unfortunately running some software that has a hard coded vmix call to ActiveInput so I can't use a cut or anything else.
I've gone back a few versions and it seems that ActivInput has never fired any triggers which seems to be a bit of an oversight.
Toby
#2 Posted : Monday, November 11, 2019 8:47:23 AM(UTC)
Seems to make sense as it doesnt do a transition or overlayin as such in order to trigger
That said as you are bound by the hard coded API call maybe you can check the state of that input (api xml) with a script and go from there for what you intent to do ? just a thought
mavik
#3 Posted : Monday, November 11, 2019 4:06:10 PM(UTC)
mavik
It's even the same if you use active input through other devices as midi controllers etc. Active input does NOT trigger anything. This is how it should work.
#4 Posted : Monday, November 11, 2019 6:29:25 PM(UTC)
Was thanked: 4677 time(s) in 1610 post(s)
This is correct, as ActiveInput does not go through any "transition" process at all, it won't trigger anything.
There is a CutDirect shortcut that is designed for what you want to do, that does call triggers, but it
sounds like if the developer of the program you are using can't change to that then there is nothing you can do unfortunately.
vmix
