Hi there
we are looking for a low profile graphic card wich is only one slot wide
will the PNY Quadro P620, 2GB GDDR5 work? or is there any other card with takes only one slot in low profile (there is no space near the PCI Slot)
found an other one
ASUS GeForce® GT 1030 2GB GDDR5 low
NVIDIA Quadro K1200 Grafikkarte 4 GB GDDR5 PCIe 2.0 x16
what's about this?
Low-profile AND single slot is a tall order. That leaves only very old cards in the running.
My desktop has a GTX 750TI that's one slot, but not low-profile. Anything prior to GTX750 doesn't have NVENC.
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 153 times Was thanked: 76 time(s) in 57 post(s)
Originally Posted by: stevespaw
I have installed these in LiveStream HD550's to convert them to vMix. A little Case Mod, some hot glue and one of these is required.
This upgrade worked very well. It made for a nice vMix setup.
Interesting. The P1000 has about half the processing power of my older GTX 750 Ti. https://gpu.userbenchmar...GTX-750-Ti/m271840vs2187Substantially less than a GTX 1660. https://gpu.userbenchmar...a-GTX-1660/m271840vs4038It's limited to 2 NVENC sessions, just like a GTX card. It's still quite capable. Would likely do anything I've ever needed. But my needs are modest.
