xaver
#1 Posted : Wednesday, October 30, 2019 5:58:58 PM(UTC)
xaver
Hi there
we are looking for a low profile graphic card wich is only one slot wide
will the PNY Quadro P620, 2GB GDDR5 work?
or is there any other card with takes only one slot in low profile (there is no space near the PCI Slot)
xaver
#2 Posted : Wednesday, October 30, 2019 6:18:12 PM(UTC)
xaver
found an other one
ASUS GeForce® GT 1030 2GB GDDR5 low
NVIDIA Quadro K1200 Grafikkarte 4 GB GDDR5 PCIe 2.0 x16
what's about this?
mjgraves
#3 Posted : Thursday, October 31, 2019 5:57:35 AM(UTC)
mjgraves
Low-profile AND single slot is a tall order. That leaves only very old cards in the running.
My desktop has a GTX 750TI that's one slot, but not low-profile. Anything prior to GTX750 doesn't have NVENC.
stevespaw
#4 Posted : Thursday, October 31, 2019 10:12:06 PM(UTC)
stevespaw
Was thanked: 75 time(s) in 57 post(s)
https://www.newegg.com/p/2VV-000D-00088
I have installed these in LiveStream HD550's to convert them to vMix. A little Case Mod, some hot glue and one of these is required.
https://www.newegg.com/startech-mdp2dvi3-mini-displayport-to-dvi/p/N82E16812400378
This upgrade worked very well. It made for a nice vMix setup.
Good Luck
Steve
mjgraves
#5 Posted : Saturday, November 2, 2019 8:11:46 AM(UTC)
mjgraves
Interesting. The P1000 has about half the processing power of my older GTX 750 Ti.
https://gpu.userbenchmar...GTX-750-Ti/m271840vs2187
Substantially less than a GTX 1660.
https://gpu.userbenchmar...a-GTX-1660/m271840vs4038
It's limited to 2 NVENC sessions, just like a GTX card.
It's still quite capable. Would likely do anything I've ever needed. But my needs are modest.
