bluesgeek
#1 Posted : Wednesday, October 23, 2019 3:25:45 PM(UTC)
bluesgeek
I use a title for events as a persistent lower third and change presets in Title Editor. I want to be able to slow down the fade between presets when I select a new one. They are too abrupt. Is there a way to do that?
Joeboe
#2 Posted : Wednesday, October 23, 2019 8:27:40 PM(UTC)
Joeboe
I do not know what you really mean, but if you right click on the effect that is between the 2 monitors, you will see the time at the bottom, just change it there
thanks 1 user thanked Joeboe for this useful post.
bluesgeek on 10/24/2019(UTC)
richardgatarski
#3 Posted : Wednesday, October 23, 2019 9:13:21 PM(UTC)
richardgatarski
bluesgeek,
I am not sure, but maybe you can fix this if you use GT's DataChangeIn/Out, see http://help.vmix.com/gra...n.html?search=datachange
bluesgeek
#4 Posted: : Thursday, October 24, 2019 3:31:02 PM(UTC)
bluesgeek
Thank you both. The issue is when changing between presets, not the transition assigned to the title. Selecting a preset makes a hard cut. I would like to set a fade time. Perhaps the GT solution is all there is, but I was hoping there was some way to work it out within the Title Editor itself.
vmix title editor sample 60pc.jpg (33kb) downloaded 1 time(s).
#5 Posted : Thursday, October 24, 2019 5:58:03 PM(UTC)
Just like Richard Gatarski said OnDataChangeIn/Out within your title animations (GT title that is , not xaml )
try the included 'Scorreboard 1 - VBA.gtzip' to see the effect when changing scores (also from presets) . btw effect only is visible when the title is in overlay !
