Title Editor - Is there a way to change fade time for presets?
I use a title for events as a persistent lower third and change presets in Title Editor. I want to be able to slow down the fade between presets when I select a new one. They are too abrupt. Is there a way to do that?
I do not know what you really mean, but if you right click on the effect that is between the 2 monitors, you will see the time at the bottom, just change it there
 1 user thanked Joeboe for this useful post.
 1 user thanked richardgatarski for this useful post.
Thank you both. The issue is when changing between presets, not the transition assigned to the title. Selecting a preset makes a hard cut. I would like to set a fade time. Perhaps the GT solution is all there is, but I was hoping there was some way to work it out within the Title Editor itself.  vmix title editor sample 60pc.jpg (33kb) downloaded 1 time(s).
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Just like Richard Gatarski said OnDataChangeIn/Out within your title animations (GT title that is , not xaml )
try the included 'Scorreboard 1 - VBA.gtzip' to see the effect when changing scores (also from presets) . btw effect only is visible when the title is in overlay !
