9 Pages<1234>»
stevespaw
#21 Posted : Thursday, October 24, 2019 1:16:09 AM(UTC)
stevespaw
Was thanked: 75 time(s) in 57 post(s)
How do I Assign inputs to the new C-G busses?
They are showing up in the input matrix of the input (in the gear), but we have no button for the output on/off. We still just have MAB on each input in the mixer.
Annotation 2019-10-23 101448.png (19kb) downloaded 5 time(s).
Annotation 2019-10-23 100612.png (22kb) downloaded 0 time(s).
Am I missing something?
Can I see more than 2 channels of Audio on the Master Out? If I want to output to BMD SDI? Can I see meters for the 8 Channels in some way?
Steve
sam602
#22 Posted : Thursday, October 24, 2019 2:25:05 AM(UTC)
sam602
Trinidad And Tobago
vMix (SRT) -> Wowza Streaming engine .. The SRT Stream does not work if the (16 or 32) passphase is assigned. Works perfect without it...
ovinas
#23 Posted : Thursday, October 24, 2019 2:46:41 AM(UTC)
ovinas
Any chance to get the new standalone version (23.0.0.1? with NDI 4) of desktop capture to test it with NDI 4 on both ends? Or does this makes no difference or sense?
ovinas
#24 Posted : Thursday, October 24, 2019 2:53:41 AM(UTC)
ovinas
Originally Posted by: stevespaw Go to Quoted Post
How do I Assign inputs to the new C-G busses?...
Out of the v23 documentation (https://www.vmix.com/help23/Mixer.html): "To enable or disable mixes C-G right click the A or B buttons to display a selection menu."
MycroBeat99
#25 Posted : Thursday, October 24, 2019 3:02:33 AM(UTC)
MycroBeat99
Romania
Another possible bug with Text. This time with Text Resizing animation.
test_lw_full.gtzip (41kb) downloaded 16 time(s). VMIX_LW_BUG.zip (985kb) downloaded 24 time(s).
#26 Posted : Thursday, October 24, 2019 3:09:25 AM(UTC)
Was thanked: 4475 time(s) in 1560 post(s)
Originally Posted by: Quinton Go to Quoted Post
I know that port 1935 is open as I use it with rtmpminiserver to send rtmp feeds from Larix broadcster into vmix via NDI, just do not understand why it works perfectly over local network, but wont connect when I try to do it over the internet?
SRT uses UDP, while RTMP uses TCP so it sounds like you don't have the UDP port open in your router/firewall.
Quinton
#27 Posted : Thursday, October 24, 2019 3:21:38 AM(UTC)
Quinton
Was thanked: 7 time(s) in 4 post(s)
Really weird thing is I seem to have it working now with Larix over my 4G, I changed it to port 1936 instead and then it seemed to work (which isnt even open in the router.
Was also doing a test with a friend in Malaysia, and I was receiving his feed without problems, but he could not receive mine on that port even though statistics said it was sending out ok, will try again using the different port when hes back on.
Seemed to be about 3 secs round trip delay from UK.
Rinsky
#28 Posted : Thursday, October 24, 2019 3:32:54 AM(UTC)
Rinsky
how does the "mini mixer" work and where can I find it?
ovinas
#29 Posted : Thursday, October 24, 2019 3:45:24 AM(UTC)
ovinas
As always, the documentation is your friend:
https://www.vmix.com/help23/index.htm?Mix.html
thanks 1 user thanked ovinas for this useful post.
Rinsky on 10/24/2019(UTC)
Gyapi
#30 Posted : Thursday, October 24, 2019 3:45:42 AM(UTC)
Gyapi
Maybe I misunderstood something in the vmix 23 beta demo video ..
Looking for HEVC live streaming ...
Thanks, Gyapi
Shilon
#31 Posted : Thursday, October 24, 2019 5:31:10 AM(UTC)
Shilon
Israel
Could someone please explain how to do a vMix to vMix SRT connection.
thanks
zenvideo
#32 Posted : Thursday, October 24, 2019 5:45:50 AM(UTC)
zenvideo
Thanks, Gyapi
AFAIK, it's for the SRT streaming (only), so can be accessed via the output settings for SRT. The options for SRT encoding include H264 & HEVC.
TV97
#33 Posted : Thursday, October 24, 2019 5:53:05 AM(UTC)
TV97
Guadeloupe
Was thanked: 10 time(s) in 5 post(s)
I made several tests between 2 VMIX with SRT, on the same network and over internert, for me it does not work at all.
sam602
#34 Posted : Thursday, October 24, 2019 6:05:39 AM(UTC)
sam602
Trinidad And Tobago
thanks
Comp 1 = caller Comp 2 = listener
1. Find out the ip addr of comp 2
2. Do ping between comp1 and comp2 ...Get ttl x 4
3. Setup comp1 using the host(comp2 ipaddr) and port 10000 latency = ttl x 4
4. Setup comp2 using host 0.0.0.0 port 10000 same latency as comp1
5. Enter all other requested information...
thanks 1 user thanked sam602 for this useful post.
TV97 on 10/24/2019(UTC)
sam602
#35 Posted : Thursday, October 24, 2019 6:12:40 AM(UTC)
sam602
Trinidad And Tobago
This is true rtmp uses 1935 tcp port ...not the 1935 udp port. Which in his case maynot be open.
MartLeib
#36 Posted : Thursday, October 24, 2019 6:28:55 AM(UTC)
MartLeib
Estonia
BUG: SRT black levels off. Using vMix input as Listener and vMix output as Caller over the public network. Colors received by SRT are washed out and black is no longer black. https://prnt.sc/pn8yrs Preview is SRT caller, Output is Listener. Problem exists both, for CPU and GPU encoding, H.264. Will try out H.265 soon.
elvis55
#37 Posted : Thursday, October 24, 2019 6:34:00 AM(UTC)
elvis55
Switzerland
Was thanked: 57 time(s) in 51 post(s)
Have tested SRT with LarixBroadcaster. Local and on the internet. Internet static IP address, port open at 1234 UPD. Local port 1235. In vMix SRT (Listener) - (Ineternet) Port 1234 - Passphrase: xxxxxx (as in LarixBroadcaster).
Works great, flows like honey.
Greeting
MartLeib
#38 Posted : Thursday, October 24, 2019 6:58:58 AM(UTC)
MartLeib
Estonia
BUG SRT: When disabling SRT streams using cog next to the External button and then enabling the same way, streams do not start. When I open one SRT setting window using the Settings - Outputs and press OK, streams start.
BUG: A/B Audio Bus Solo not following headphone level set under Master fader. Always on 100%, have not checked other buses.
TV97
#39 Posted : Thursday, October 24, 2019 7:45:18 AM(UTC)
TV97
Guadeloupe
Thank to Sam602
I just tested the 2 computers VMIX distant 3 kms, with your method, I just set the port opening of each modem with internal ip address of each PC (VMIX1 mode listener -Port 1935 - VMIX2 mode listener - port 1936). Now every VMIX is broadcasting a movie.
- After On VMX1: Input SRT Caller / Hostname: public ip address of the VMIX2 / Port 1936 router
- After On VMX2: Input SRT Caller / Hostname: Public IP address of the VMIX1 / Port 1935 router.
Without passphrase, with 200ms latency, Quality: H264 10 mbps.
And here everything works perfectly each VMIX receives the other remote video concern, with video quality at the top
1 continuous test hour between 2 VMIX, with a rectilinear and perfect transmission regularity.
Excuse my bad english.
MartLeib
#40 Posted : Thursday, October 24, 2019 8:58:24 AM(UTC)
MartLeib
Estonia
SRT Enhancement: SRT Audio Bitrate = SUM for all the Audio buses, make it clearer that it is total for the SRT stream, if you select 128kbs, and you would stream 4 audio buses, each bus will get only 32Kbps. Probably it should go to the docs only, not in the UI (UI wise it is correct to input one total sum for all the streams due to ease for bandwidth calculations)
SRT BUG?: When selecting MABCDEFG for SRT Audio channels, SRT is not sent. Disallow enabling SRT and selecting more than 4 audio buses.
SRT BUG: Audio channel 4 always quieter and distorted, sounds like LFE. Probably due to 5.1/7.1 encoding.
Guest (8)
9 Pages<1234>»
