How to suppress the API response messages?
Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
I want to control vMix with a touchscreen. I can use the web interface but the colors and size of the buttons can't be modified.
I created a html page with a number of presets. That works but after every buttonpress a new page shows up with "Function completed successfully" How can I suppress this response message?
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
Hi A quick and crewd way would be it have 2 HTML frames , one for your buttons and a small empty one that you target your buttons at , this way the buttons will stay and you will still see the server response
Ok, thanks, I will try that. It's a pitty that the api doesn't have a return url option.
