wwdv
#1 Posted : Saturday, November 16, 2013 3:10:03 PM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
I want to control vMix with a touchscreen.
I can use the web interface but the colors and size of the buttons can't be modified.
I created a html page with a number of presets.
That works but after every buttonpress a new page shows up with "Function completed successfully"
How can I suppress this response message?
Henny
#2 Posted : Sunday, November 17, 2013 2:41:45 AM(UTC)
Henny
Was thanked: 28 time(s) in 24 post(s)
Hi
A quick and crewd way would be it have 2 HTML frames , one for your buttons and a small empty one that you target your buttons at , this way the buttons will stay and you will still see the server response
wwdv
#3 Posted : Sunday, November 17, 2013 7:13:09 AM(UTC)
wwdv
Ok, thanks, I will try that.
It's a pitty that the api doesn't have a return url option.
