66 Pages«<3637383940>»
chococrispis35
#741 Posted : Saturday, October 5, 2019 1:36:38 AM(UTC)
chococrispis35
elgraf: and cpu is overloaded
chococrispis35
#742 Posted : Saturday, October 5, 2019 1:48:07 AM(UTC)
chococrispis35
Elgarf check the video:
elgarf
#743 Posted : Sunday, October 6, 2019 5:35:39 PM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
@chococrisps, try this:
Download
郭子涵
#744 Posted : Monday, October 7, 2019 10:36:27 PM(UTC)
郭子涵
Rank:: Member
China
Download
Hi,elgarf,Can I control "colour key"?
chococrispis35
#745 Posted : Tuesday, October 8, 2019 2:47:07 AM(UTC)
chococrispis35
Elgarf i tested, the audio, is fixed, working fine, but on change title to next row the video freezes, and cpu-Vmix up to 69%. On version of utc 24-03-2019 working fine, and other suggestion: the buttons always are black, only outline change the color,
you can modify the button color y select a color for inside for each button and not only outline? Thanks
elgarf
#746 Posted : Tuesday, October 8, 2019 1:44:13 PM(UTC)
elgarf
Russian Federation
@郭子涵, if there is no API functions for this, you can't (
@chococrisps35, I don't change anything related next/previous row or scripting at all. Can you switch on log, and send me it?
chococrispis35
#747 Posted : Thursday, October 10, 2019 12:42:55 AM(UTC)
chococrispis35
i need your email elgarf for send the log
kevev
#748 Posted : Saturday, October 12, 2019 5:18:56 PM(UTC)
kevev
Was thanked: 9 time(s) in 5 post(s)
Great work Elgarf!
Some suggestions:
1.) On the score input widget, when setting to zero "0", the vMix overlay index does not show a zero. It actually shows blank. Any way to make the zero actually show?
2.) Some widgets allow selecting an index for editing. Others only allow entering an index number. It would be easier if all widngets had pull down menus to allow us to select the index.
elgarf
#749 Posted : Monday, October 14, 2019 7:51:03 PM(UTC)
elgarf
Russian Federation
@kevev,
1) I'll try to fix this.
2) Not sure I understood you, indexes are not in list format into button widget, because of expression into index field.
kevev
#750 Posted : Tuesday, October 15, 2019 5:30:32 AM(UTC)
kevev
@kevev,
What I mean is can we have all of the widget types have a pulldown menu for selecting the index name that the widget changes? Some widgets only have a text field for entering an index number. That is not good as we have to guess the index number.
elgarf
#751 Posted : Tuesday, October 15, 2019 7:23:09 PM(UTC)
elgarf
Russian Federation
@kevev, you can see index number into API result from http://127.0.0.1:8088/api
For example, here is my script for updating score, based on set number. I can't use dropdowns in [Index] property, because my indexes are not predefined =(
Annotacija 2019-10-15 141905.png (62kb) downloaded 14 time(s).
Btw, there is no dropdowns only in button script
elgarf
#752 Posted : Tuesday, October 15, 2019 9:07:19 PM(UTC)
elgarf
Russian Federation
@chococrispis35, I still waiting log=(
Snooker Loopy
#753 Posted : Tuesday, October 15, 2019 11:11:06 PM(UTC)
Snooker Loopy
Hi elgarf,
Been a while since I was able to get on the forum - hope everyone's ok :-)
I would like to run two instances of UTC - one on a tablet and the other on the local laptop running VMix. I'm able to do this but there is a small issue.
The reason behind running two instances is:
1. Quite often there is only one person controlling four separate streams (VMix and UTC on each one) so if some of the workload can be done by other people then that's a bonus.
2. Because of this I'd like the Referee at the table to control the scoring and the stream control desk can do everything else.
It seems to work well but if the REFEREE tries to update the score after I'VE changed something within UTC then it doesn't function without the REFEREE pressing 'Sync' first (and vice versa). (Capitals only used to differentiate between the two instances - I'm really not shouting).
Is there any way to have the two instances auto sync to address this issue? Maybe something that could be switched on or off to suit people's requirements.
elgarf
#754 Posted : Wednesday, October 16, 2019 3:14:02 AM(UTC)
elgarf
Russian Federation
@Snooker Loopy, you can make button, which call sync every N seconds, script should be like:
1) UpdateState
2) Timer 1000 (or less or more)
3) GoTo 1
You also can execute this script on UTC startup.
thanks 1 user thanked elgarf for this useful post.
Snooker Loopy on 10/16/2019(UTC)
Snooker Loopy
#755 Posted : Wednesday, October 16, 2019 4:47:10 AM(UTC)
Snooker Loopy
1) UpdateState
3) GoTo 1
@elgarf, Thanks for your advice, think I've got the button working correctly but not sure how to execute on UTC start up. Do I put a tick in the box for 'Execute After Load' to achieve that part? Also, do I need to do the script on both instances of UTC?
kevev
#756 Posted : Wednesday, October 16, 2019 11:23:05 AM(UTC)
kevev
I am not sure I understand. I did look at the API. The images indexes are not listed. Is this why UTC is not able to just have a list of the images index for setting?
If this is true, is there another way to get the images indexes?
elgarf
#757 Posted : Wednesday, October 16, 2019 1:35:00 PM(UTC)
elgarf
Russian Federation
@Snooker Loopy, yep. Tick "Execute After Load", so script executes on loading your controller.
If you want see changes from referee, you can make this button on both controllers, BUT I think you can get problems with syncing (what if referee and you change one title at the same time)?
The best way is make completely different controllers for each person, I think.
@kevev, that's not as simple.
1) You can select index from dropdown menu in text field, score, etc. because that's simple widgets, they do one thing and nothing else.
2) Button is scriptable - it can do anything you want, but there are some inconveniences. One of them - indexes are not in dropdown list, mainly because index can be calculated from another values.
kevev
#758 Posted : Friday, October 18, 2019 12:20:43 PM(UTC)
kevev
Would it be possible to make a simple button widget?
curtismacd31
#759 Posted : Sunday, October 20, 2019 4:50:06 AM(UTC)
curtismacd31
EDIT: SOLVED!
I found @DWAM's post
A newbie question here. Is it possible to use an if statement to drive the data in a text field?
Here is what I am trying to do on a simple level. I have a period selection and I am using two separate text fields to have two different fonts and sizes for text.
When I select Period 1 I would like to have an if statement that is something like "If Period = 1 then PeriodEndText = ST".
Currently what I am doing is just manually selecting 1 and the typing ST in a text field I placed beside it. It works that way I am just trying to make it a bit more dummy-proof. lol
Thanks for the help
elgarf
#760 Posted : Monday, October 21, 2019 4:44:43 PM(UTC)
elgarf
Russian Federation
@kevev, not sure it will be such useful =( Btw, I'll think about it. Maybe there will be helper for scripting.
@curtismacd31, good to know you found solution. Scripting is also possible, but solution with list widget is simplier.
Guest (10)
