Hardware Compatibility
HDMi Single channel acquisition via USB 3
Hi everybody ! On the internet I found many single HDMi channel acquisition devices via USB even at 50 : 60 US $ Have any of you had positive experiences and can you recommend a brand and / or model? Thank a lot Ciao
Joined: 3/17/2017(UTC) Posts: 455  Location: Luzern - Schweiz Thanks: 69 times Was thanked: 58 time(s) in 52 post(s)
I've had good results with the El Gato CamLink. Not in that sub-$100 range, but a name brand. https://www.mgraves.org/...mi-capture-on-the-cheap/It appears in the tablet of recommended devices. The table says "progressive sources only" which is no longer correct. A firmware update added support for interlaced formats. In the dirt cheap, non-branded knockoffs category there are too many to even list. Largely unsupported.
