etruxo
#1 Posted : Wednesday, October 9, 2019 4:55:28 AM(UTC)
etruxo
Italy
Hi everybody !
On the internet I found many single HDMi channel acquisition devices via USB even at 50 : 60 US $
Have any of you had positive experiences and can you recommend a brand and / or model?
Thank a lot
Ciao
elvis55
#2 Posted : Wednesday, October 9, 2019 5:24:08 PM(UTC)
elvis55
Switzerland
For still images ok. Not usable for moving pictures and camera pans.
Recommended, those are the vMix tested.
Greeting
mjgraves
#3 Posted : Thursday, October 10, 2019 1:49:05 AM(UTC)
mjgraves
I've had good results with the El Gato CamLink. Not in that sub-$100 range, but a name brand.
https://www.mgraves.org/...mi-capture-on-the-cheap/
It appears in the tablet of recommended devices. The table says "progressive sources only" which is no longer correct. A firmware update added support for interlaced formats.
In the dirt cheap, non-branded knockoffs category there are too many to even list. Largely unsupported.
