Feature Requests
Option to take Snapshot and create new input with it at the same time
Joined: 9/1/2017(UTC) Posts: 16 Location: Oakland, CA
I'd love to have the option in the "Take image snapshot of Output" menu to load that snapshot right back into vMix automatically as a new input.
I was able to modify a script to do that process but it'd be great to have be automatic.
Joined: 12/27/2012(UTC) Posts: 5,536  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Shortcuts can do it too ;-)
How you program a shortcut to take a snapshot and make it available as an input in vMix automatically? I can make a shortcut of the script but I'm not seeing an existing shortcut that takes a snapshot and loads it up as an input.
when you have a shortcut (Snapshot or SnapshotInput) to take an snapshot you can give it a name There is a shortcut (AddInput) to load an image and specify the snapshot's name combine both under the same shortcut key ( in correct order ) then you have ....
Somewhat more complex one would be to create a script (triggered by a shortcut) that instructs to take a snapshot, let the script search in the specific folder for the latest snapshot saved and instruct to load that as an Image input
Feature Requests
