kirik
#1 Posted : Tuesday, October 1, 2019 12:45:10 AM(UTC)
kirik
Russian Federation
Greetings!
We have been using vmix for a long time. For a long time, the low frequency of updating the sound levels has been slightly annoying. I noticed that this frequency is approximately equal to 12-16 FPS. Sometimes this frequency is not enough for full monitoring of clock noise and instant deviations of the level from the norm (very fast overload, very fast signal loss). I understand that vmix is ​​not an audio software, but still I think that this is a very important point in the broadcast. Do you plan to increase this FPS at least 2 times faster?
the point is that the low refresh rate misses some of the loudness measurements. so you can skip overdrive peaks or dips
Click for GIF!
2021-11-06 21-36-23_1.gif (2,392kb) downloaded 11 time(s).
mjgraves
#2 Posted : Tuesday, October 1, 2019 1:07:58 AM(UTC)
mjgraves
I'm not sure that rate of update is what you're after. It could be that you want different metering ballistics. Instantaneous peak vs RMS weighted reading.
zenvideo
#3 Posted : Tuesday, October 1, 2019 2:57:48 AM(UTC)
zenvideo
You could maybe use a 3rd party 64-bit VST3 meter plugin, like mvMeter2 from tb-software.com.Lots of options for meter scales & display size, and runs at the GUI/screen refresh rate. Only missing feature I can see is no Always-On-Top option for the window, so you would probably need to drag it onto a different display so it doesn't get covered when you click on the vMix GUI.
mjgraves
#4 Posted : Tuesday, October 1, 2019 5:46:56 AM(UTC)
mjgraves
I sometimes use a meter that's entirely separate. It's from Darkwood Designs: https://darkwooddesigns.co.uk/pc2/widerange.html
Very configurable. It can hook into any audio device. Point it at the source device and away you go.
elvis55
#5 Posted : Tuesday, October 1, 2019 6:24:05 AM(UTC)
elvis55
Switzerland
zenvideo
#6 Posted : Wednesday, October 2, 2019 2:50:50 AM(UTC)
zenvideo
Yes, Paul at Darkwood has created a range of useful audio meters, a couple of which I've used for many years. They need to take a feed from a Windows sound Input Device, which means it's not necessarily possible to "hook" them into a vMix input or bus quite as easily as a VST plug-in, but if that's not an issue then they are an excellent choice and do have an Always-On-Top option for the meter window, which is very useful. (BTW, I did ask him a while back if he'd consider adding NDI input as an option, but I don't think he's wanting to continue development and add anything new.)
kirik
#7 Posted : Sunday, November 14, 2021 4:33:51 AM(UTC)
kirik
Russian Federation
I made a gif for visual sense of the difference. Click on gif
