voyagermix
#1 Posted : Saturday, September 28, 2019 11:04:00 AM(UTC)
voyagermix
Mexico
how can I do this:?
datasource
In my city I want to cover races, marathons, etc., but I would like to put the data of those who cross the finish line.
I have the computer that throws that data. just have to put it in VMix
but how?
stigaard
#2 Posted : Saturday, September 28, 2019 5:37:02 PM(UTC)
stigaard
Denmark
What is the data format that you got?
voyagermix
#3 Posted : Sunday, September 29, 2019 6:59:19 AM(UTC)
voyagermix
Mexico
I want to add the data enclosed in green, and the rows, five runners on screen.
csv
.CSV
Peter1000
#4 Posted : Sunday, September 29, 2019 4:24:11 PM(UTC)
Peter1000
Switzerland
Was thanked: 82 time(s) in 62 post(s)
Maybe you take a short look at the manual.
If you google „vmix excel data title“, you will find at first position:
https://www.vmix.com/hel...dex.htm?DataSources.html
voyagermix
#5 Posted : Tuesday, October 1, 2019 4:15:55 AM(UTC)
voyagermix
Mexico
thanks Peter, but in the manual it doesn't come as choosing Row1, Row2, Row3 at the same time.
Apparently it's just a row and it's all.
stigaard
#6 Posted : Tuesday, October 1, 2019 4:40:35 AM(UTC)
stigaard
Denmark
You can manipulate the data such that All rows are being populated as one row. E.g. row 1 go into column 1 to 5, row 2 goes into column 6 to 10, and so on. Then you are able to map All the data.
thanks 1 user thanked stigaard for this useful post.
voyagermix on 10/1/2019(UTC)
#7 Posted : Tuesday, October 1, 2019 4:50:41 AM(UTC)
Was thanked: 1013 time(s) in 832 post(s)
As stigaard says
You can then tell the data source to convert rows to columns (column will get an additional number )
Meaning all is now on one line ( see help files) . This will make it possible to display the ranking fields being line 1 = name1,time1, line 2 = name2, time2 end so on
If you can , it would make things a bit easier to filter needed data out a little like not men and woman in one file
Peter1000
#8 Posted : Tuesday, October 1, 2019 5:11:50 AM(UTC)
Peter1000
Switzerland
t1.PNG (21kb) downloaded 0 time(s). t2.PNG (38kb) downloaded 0 time(s). t3.png (30kb) downloaded 0 time(s).
thanks 1 user thanked Peter1000 for this useful post.
voyagermix
#9 Posted : Tuesday, October 1, 2019 8:49:14 AM(UTC)
voyagermix
Mexico
Wow thanks!!!> stigaard doggy Peter1000
funcionó!
it worked :)
