Joined: 2/10/2015(UTC) Posts: 34   Location: La Paz, MX Thanks: 9 times
how can I do this:?  In my city I want to cover races, marathons, etc., but I would like to put the data of those who cross the finish line. I have the computer that throws that data. just have to put it in VMix but how?
What is the data format that you got?
I want to add the data enclosed in green, and the rows, five runners on screen. . .CSV
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
thanks Peter, but in the manual it doesn't come as choosing Row1, Row2, Row3 at the same time.
Apparently it's just a row and it's all.
You can manipulate the data such that All rows are being populated as one row. E.g. row 1 go into column 1 to 5, row 2 goes into column 6 to 10, and so on. Then you are able to map All the data.
 1 user thanked stigaard for this useful post.
As stigaard says You can then tell the data source to convert rows to columns (column will get an additional number ) Meaning all is now on one line ( see help files) . This will make it possible to display the ranking fields being line 1 = name1,time1, line 2 = name2, time2 end so on
If you can , it would make things a bit easier to filter needed data out a little like not men and woman in one file
 t1.PNG (21kb) downloaded 0 time(s). t2.PNG (38kb) downloaded 0 time(s). t3.png (30kb) downloaded 0 time(s).
 1 user thanked Peter1000 for this useful post.
Wow thanks!!!> stigaard doggy Peter1000 it worked :)
