Simsyuk
#1 Posted : Tuesday, August 27, 2019 5:31:16 PM(UTC)
Simsyuk
Was thanked: 22 time(s) in 17 post(s)
Not sure if this is possible, I've looked at the triggers and I can't find anything to do with virtual sets!
I have a trigger that starts my custom virtual set on full, it then shows some animations and lower thirds etc.
Is it possible to have a trigger (lets say after 30 seconds) to go from full to close up automatically?
Thank you in advance,
Sims
Simsyuk
#2 Posted: : Tuesday, August 27, 2019 6:01:36 PM(UTC)
Simsyuk
Ignore, I've figured it out :D
#3 Posted : Tuesday, August 27, 2019 6:14:54 PM(UTC)
Was thanked: 967 time(s) in 801 post(s)
first off after a search in this forum
https://forums.vmix.com/...5-Virtual-Set--Shortcuts
that being said it doesnt work as a trigger BUT one can TRIGGER a shortcut ;-)
#4 Posted : Tuesday, August 27, 2019 6:22:20 PM(UTC)
Guess other forum members will appreciate your figured it out solution :D
Simsyuk
#5 Posted : Tuesday, August 27, 2019 6:57:38 PM(UTC)
Simsyuk
Yeah sure, I just placed a trigger in the title (it only shows once at the biginning) - I gave it a delay of 20 seconds.
For the first 5 mimutes I don't have to do anything:
Promo starts about my online content (has a countdown clock) - this allows online viewers to see how long before we go live.
Once countdown completes, trigger my virtual set on full
on TransitionOut - load overlays for my lower thirds
On overlay In - OverlayInput4 (15000 delay)
On overlay out - cut to virtual set closeup (0 delay)
Tested and works great - Triggers are great :D
#6 Posted : Tuesday, August 27, 2019 7:02:15 PM(UTC)
Confused TO CLOSE or go into CLOSEUP ! and as a cut not a move to ?
Simsyuk
#7 Posted : Tuesday, August 27, 2019 7:18:07 PM(UTC)
Simsyuk
Please view attached image. vmix_closeup.jpg (115kb) downloaded 0 time(s).
#8 Posted : Tuesday, August 27, 2019 7:20:44 PM(UTC)
ok then , ignore my first response as that was meant to zoom in automatically after certain time within the virtual set
Simsyuk
#9 Posted : Tuesday, August 27, 2019 7:25:55 PM(UTC)
Simsyuk
No problem at all, I'm still learning. I did try the zoom but it wasn't what I wanted (including shortcuts) - shame one can't add a shortcut for the vertiual sets (yet).
#10 Posted : Tuesday, August 27, 2019 7:39:27 PM(UTC)
some you can , see link i gave, all depends what you want to do
