Joined: 8/16/2019(UTC) Posts: 340 ![United Kingdom United Kingdom](/Content/images/flags/GB.png) Thanks: 74 times Was thanked: 21 time(s) in 17 post(s)
Not sure if this is possible, I've looked at the triggers and I can't find anything to do with virtual sets!
I have a trigger that starts my custom virtual set on full, it then shows some animations and lower thirds etc.
Is it possible to have a trigger (lets say after 30 seconds) to go from full to close up automatically?
Thank you in advance, Sims
Ignore, I've figured it out :D
Joined: 12/27/2012(UTC) Posts: 5,130 ![Belgium Belgium](/Content/images/flags/BE.png) Location: Belgium Thanks: 285 times Was thanked: 929 time(s) in 767 post(s)
Originally Posted by: Simsyuk ![Go to Quoted Post Go to Quoted Post](/Themes/yafpro/icon_latest_reply.gif) Ignore, I've figured it out :D Guess other forum members will appreciate your figured it out solution :D
Yeah sure, I just placed a trigger in the title (it only shows once at the biginning) - I gave it a delay of 20 seconds.
For the first 5 mimutes I don't have to do anything:
Promo starts about my online content (has a countdown clock) - this allows online viewers to see how long before we go live. Once countdown completes, trigger my virtual set on full on TransitionOut - load overlays for my lower thirds
On overlay In - OverlayInput4 (15000 delay) On overlay out - cut to virtual set closeup (0 delay)
Tested and works great - Triggers are great :D
Confused TO CLOSE or go into CLOSEUP ! and as a cut not a move to ?
Originally Posted by: doggy ![Go to Quoted Post Go to Quoted Post](/Themes/yafpro/icon_latest_reply.gif) Confused TO CLOSE or go into CLOSEUP ! and as a cut not a move to ? Please view attached image. ![](/Themes/yafpro/icon_file.gif) vmix_closeup.jpg (115kb) downloaded 0 time(s).
ok then , ignore my first response as that was meant to zoom in automatically after certain time within the virtual set
Originally Posted by: doggy ![Go to Quoted Post Go to Quoted Post](/Themes/yafpro/icon_latest_reply.gif) ok then , ignore my first response as that was meant to zoom in automatically after certain time within the virtual set No problem at all, I'm still learning. I did try the zoom but it wasn't what I wanted (including shortcuts) - shame one can't add a shortcut for the vertiual sets (yet).
Quote: shame one can't add a shortcut for the vertiual sets (yet).
some you can , see link i gave, all depends what you want to do
