topherharris
#1 Posted : 6 years ago
topherharris
The error message I'm getting: "ERROR: The remote server returned an error. (403) Forbidden"
I've followed the instructions here first on how to create a Google API Key for Google Sheets" - https://www.vmix.com/hel...ex.htm?GoogleAPIKey.html
I then tried to add the API key I created as well as the "Shareable link" to a test Google Sheets doc.
Am I missing a step?
Thanks,
Christopher
System Profile:
vMix Pro 22.0.0.67
Windows 10 Enterprise v1803
Intel Xeon CPU E5-2687W v4 3.00GHZ
64 GB RAM
NVIDIA GeForce GTX 1080
IanM
#2 Posted : 6 years ago
IanM
When you did 'Share' on the sheet, did you click the 'Get shareable link' on the pop up. That seemed to do it for me.
topherharris
#3 Posted : 6 years ago
topherharris
Yup, I did that. Unfortunately, the ability to share at our site is limited globally in our G Suite. Meaning, we can't make a Google Sheets document "Public."
So, unless there's a way to log in via the vMix Data Source manager, it's not going to happen.
-topher
PopisDad
#4 Posted : 4 years ago
PopisDad
Desperate to know if you ahev been killed by your boss, but more importantly did you solve the problem with the 'forbidden' error?
PopisDad
#5 Posted : 4 years ago
PopisDad
I had everything working fine yesterday, and yet running again this morning I am getting the 'forbidden' error...
Any clues as to what may have changed? I have double checked the two main entries for the API and the Google Sheets location.
PopisDad
#6 Posted : 4 years ago
PopisDad
UPDATE: All working as expected now. It seems the issue is to keep Google Credential Restrictions to 'None'!
