Google Sheets Error Message
Joined: 8/21/2019(UTC) Posts: 13  Location: Pasadena, CA Thanks: 3 times Was thanked: 2 time(s) in 2 post(s)
The error message I'm getting: "ERROR: The remote server returned an error. (403) Forbidden" I've followed the instructions here first on how to create a Google API Key for Google Sheets" - https://www.vmix.com/hel...ex.htm?GoogleAPIKey.htmlI then tried to add the API key I created as well as the "Shareable link" to a test Google Sheets doc. Am I missing a step? Thanks, Christopher System Profile: vMix Pro 22.0.0.67 Windows 10 Enterprise v1803 Intel Xeon CPU E5-2687W v4 3.00GHZ 64 GB RAM NVIDIA GeForce GTX 1080
Joined: 8/3/2019(UTC) Posts: 21  Location: London Thanks: 1 times
When you did 'Share' on the sheet, did you click the 'Get shareable link' on the pop up. That seemed to do it for me.
Originally Posted by: IanM  When you did 'Share' on the sheet, did you click the 'Get shareable link' on the pop up. That seemed to do it for me. Yup, I did that. Unfortunately, the ability to share at our site is limited globally in our G Suite. Meaning, we can't make a Google Sheets document "Public." So, unless there's a way to log in via the vMix Data Source manager, it's not going to happen. -topher
Joined: 7/24/2014(UTC) Posts: 30 Location: Milton Keynes, UK
Desperate to know if you ahev been killed by your boss, but more importantly did you solve the problem with the 'forbidden' error?
I had everything working fine yesterday, and yet running again this morning I am getting the 'forbidden' error...
Any clues as to what may have changed? I have double checked the two main entries for the API and the Google Sheets location.
UPDATE: All working as expected now. It seems the issue is to keep Google Credential Restrictions to 'None'!
