danrossi
#1 Posted : Thursday, July 25, 2019 8:17:44 AM(UTC)
danrossi
I am trying to test a multi track video with alternate language tracks over RTMP to Wowza as a proof of concept. Only two channels and one track is sent. Is there a way to make this work. Or can this software publish as mpeg-ts ?
Lennart
#2 Posted : Monday, July 29, 2019 6:57:03 AM(UTC)
Lennart
Denmark
Was thanked: 17 time(s) in 16 post(s)
I think you might be able to use the FFMPEG option to manually set it up for that.
Found some hints to multiple audio tracks here:
https://video.stackexchange.com/questions/21734/ffmpeg-video-conversion-with-multiple-audio-tracks
I honestly don't know enough about it to find the exact commands you'd need, I'd actually like to find a way of doing this my self.
desmar
#3 Posted : Monday, July 29, 2019 9:49:38 AM(UTC)
desmar
Canada
vMix only does 1 video and 1 (L + R) audio track. Even though FFMPEG does support multi-channel audio, vMix does not use that feature of FFMPEG..
dark_ata
#4 Posted : Thursday, August 8, 2019 10:28:46 PM(UTC)
dark_ata
Was thanked: 18 time(s) in 13 post(s)
it is possible in the streaming setting you can change the audio for ALL of the destinations, we usually send the 2-4 languages and in the master server split the audio using ffmpeg.
#5 Posted : Friday, August 9, 2019 8:31:02 PM(UTC)
@ danrossi
Actually, vMix can send different audio busses to each stream destination.
(Master, Bus A and Bus B as selected in Stream Audio settings).
If your Video is multi-track however, you may not be able to playback alternate tracks as vMix only supports two channel stereo playback of video files.
danrossi
#6 Posted : Friday, August 9, 2019 8:32:44 PM(UTC)
danrossi
Its ok thanks. I'm testing UDP with OBS and hopefully SRT.
Barney Box Lane
#7 Posted : Friday, August 9, 2019 8:50:02 PM(UTC)
Barney Box Lane
requested that to newtek (ndi) so would be worth following up as they're looking into ideas
Guest (5)
