I am trying to test a multi track video with alternate language tracks over RTMP to Wowza as a proof of concept. Only two channels and one track is sent. Is there a way to make this work. Or can this software publish as mpeg-ts ?
Joined: 11/9/2014(UTC) Posts: 106   Location: Copenhagen, Denmark Thanks: 22 times Was thanked: 17 time(s) in 16 post(s)
Joined: 8/21/2015(UTC) Posts: 324   Location: Cornwall, Ontario, Canada Thanks: 18 times Was thanked: 80 time(s) in 60 post(s)
vMix only does 1 video and 1 (L + R) audio track. Even though FFMPEG does support multi-channel audio, vMix does not use that feature of FFMPEG..
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
it is possible in the streaming setting you can change the audio for ALL of the destinations, we usually send the 2-4 languages and in the master server split the audio using ffmpeg.
Joined: 3/7/2012(UTC) Posts: 2,690  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ danrossi
Actually, vMix can send different audio busses to each stream destination. (Master, Bus A and Bus B as selected in Stream Audio settings). If your Video is multi-track however, you may not be able to playback alternate tracks as vMix only supports two channel stereo playback of video files.
Its ok thanks. I'm testing UDP with OBS and hopefully SRT.
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
requested that to newtek (ndi) so would be worth following up as they're looking into ideas
