AgentPete
#1 Posted : Wednesday, August 7, 2019 1:31:45 AM(UTC)
AgentPete
Was thanked: 9 time(s) in 3 post(s)
I’m wondering whether anyone has found a way to open the vMix Web browser from a url held in a Data Source (e.g. Excel spreadsheet)?
Currently you have to manually input the URL. Might this be possible via scripting?
#2 Posted : Wednesday, August 7, 2019 2:42:04 AM(UTC)
Data Sources is for titles, don't see how you could link a webaddress from a datasource to another type of input (browser)
on the other hand have you checked the Shortcut reference list , there is a Browser section that allows you to navigate a browser input. As such this can be used in a script also or externally with the web API (httprequest)
burie
#3 Posted : Wednesday, August 7, 2019 3:32:31 AM(UTC)
burie
Germany
How does this work? It is one of the things I urgently need. Call a website, especially a PHP-script by pressing a key, a shortkey or anything like this. I don't need a input, the script only writes a XML-file, no visible outputs needed.
I have absolutely no idea about VB.NET scripting and new with vmix... so I would be happy and thankful for any help
And NO... a datasource with these PHP-Script is no option because as datasource these script would be refresh second by second but i need it only ONE time.
#4 Posted : Wednesday, August 7, 2019 3:50:08 AM(UTC)
As mentioned earlier you could do the same by sending the link/url (via shortcut) to you php script from a browser input (just as you would from your regular browser basically)
or learn a little bit of vb.net in how to send a httprequest containing your link and put that in a vMix script and link that to a shortcut
#5 Posted : Wednesday, August 7, 2019 3:59:39 AM(UTC)
If you really want to do that call from within vMix :
burie
#6 Posted : Sunday, August 18, 2019 2:08:57 PM(UTC)
burie
Germany
I know that way to call a website, but if I wanna do two or more things with ONE Shortkey...
I also know to make multiple entries in shortkey list for one key, but I think if one of the entries is "call a website" the other will not be executed.
Anyway... i have found a completely different solution using PHP, so thank you for your help... and this could be closed...
ranz
#7 Posted : Friday, March 18, 2022 12:56:20 AM(UTC)
ranz
So I've been playing with this idea also.
In my show I've got to load up a number of youtube videos - which changes every show.
What I ended up doing is similar to the advice above - as follows:
1. Setup google sheets with a column listing the URLs (follow instructions on how to do this in the vMix help docs)
2. Using "Shortcuts" in settings - Create a shortcut to your controller using BrowserNavigate - add the URL (see below)
3. Setup another shortcut to add the video input to your output
I used PHP to grab the link from the Google Sheets:
I named a PHP file "getUrl.php" - placed it on a local VirtualBox that Vmix could see over the LAN
Code here:
<?php
$column = $_REQUEST['column'];
$column = $column +1;
$myArray = google_sheet('put your google sheets URL here');
header('Location: ' . $myArray[$column]['C']);
exit;
function google_sheet($url = NULL) {
$array = array();
if ($url):
// initialize curl
$curl = curl_init();
curl_setopt($curl, CURLOPT_URL, $url);
curl_setopt($curl, CURLOPT_HEADER, 0);
curl_setopt($curl, CURLOPT_RETURNTRANSFER, TRUE);
// get the spreadsheet data using curl
$sheet = curl_exec($curl);
curl_close($curl);
// find the table pattern and return the mark-up
preg_match('/(<table[^>]+>)(.+)(<\/table>)/', $sheet, $matches);
$data = $matches['0'];
// convert the HTML (XML) mark-up to JSON
$cells_xml = new SimpleXMLElement($data);
$cells_json = json_encode($cells_xml);
$cells = json_decode($cells_json, TRUE);
endif;
// Convert the JSON array to an array of just the table data
// This will strip out any Google Sheets formatting and identifiers if they exist
if ( is_array($cells) ):
foreach ($cells['tbody']['tr'] as $row => $row_data):
$column = 'A';
foreach ($row_data['td'] as $column_index => $cell):
// Check that the cell is populated and get the value.
if (!is_array($cell)):
$array[($row + 1)][$column++] = $cell;
elseif ($cell['div']):
$array[($row + 1)][$column++] = $cell['div'];
endif;
endforeach;
endforeach;
endif;
return $array;
I didn't bother too much about security in the script as it is only seen from inside my PC with Vmix running on it.
Back to the "Shortcut" with BrowserNavigate - put the link to your virtualbox php script like:
http://10.0.0.1/getUrl.php?column=1
you can change the column numbers as you add more URL shortcuts (in my case I can sometimes have up to 6) - so you just change the ?column=6 part to reflect which column you want.
The redirect part of the script is a little annoying - but so long as you press it only once on your controller - it should be all set for the show :) - then just queue them up in your preview and away you go :)
oh and I have Column C as my "URL" column in google sheets - you can change this to whatever you like in the code.
Enjoy :)
MartLeib
#8 Posted : Friday, March 18, 2022 3:41:13 AM(UTC)
MartLeib
Estonia
I would create dummy title and set it's text field using data source. Now I would loop a script every one second to check, is the addresss changed, if it is, navigate browser input using API to that URL. Done.
