YOUTUBE BUFFERING IN 10mpb upload speed
You have been a member since:: 8/5/2019(UTC) Posts: 2  Location: lagos
I bought the vmix software and was using the youtube streaming feature after a while every time i start the streaming it wont show on youtube, but on the vmix software it's showing that the streaming is on, after much research i wouldn't see a solution i decide to use the alternative, youtube live. This one has an issue which is, at 1080 HD streaming with a speed of 9mpbs it breaking and buffering , what is the cause of it?
What is the upload speed of your connection?
What are your frames per second for 1080P?
My upload speed is 8mpbs,the frame per second is 29
Your current streaming bitrate is beyond your upload speed. Ideally your connection upload speed should be double what the streaming speed is. So if you run a speed test on the Internet connection and it's 8mbps, then you should stream at 1080P/29.97 with a bitrate of 4mbps. Try that bitrate and see if it is stable. You may be able to go up to 5mbps, but do a long term test. If there are issues, go back down to 4mbps. Here are recommendations for live encoder settings from YouTube: https://support.google.c...ube/answer/2853702?hl=en
 1 user thanked SportsNetUSA.net for this useful post.
