impact
#1 Posted : Monday, August 5, 2019 5:45:35 AM(UTC)
impact
Nigeria
I bought the vmix software and was using the youtube streaming feature after a while every time i start the streaming it wont show on youtube, but on the vmix software it's showing that the streaming is on, after much research i wouldn't see a solution i decide to use the alternative, youtube live.
This one has an issue which is, at 1080 HD streaming with a speed of 9mpbs it breaking and buffering , what is the cause of it?
SportsNetUSA.net
#2 Posted : Monday, August 5, 2019 7:30:51 AM(UTC)
SportsNetUSA.net
What is the upload speed of your connection?
What are your frames per second for 1080P?
impact
#3 Posted : Monday, August 5, 2019 4:32:48 PM(UTC)
impact
Nigeria
My upload speed is 8mpbs,the frame per second is 29
SportsNetUSA.net
#4 Posted : Tuesday, August 6, 2019 2:34:12 AM(UTC)
SportsNetUSA.net
Your current streaming bitrate is beyond your upload speed. Ideally your connection upload speed should be double what the streaming speed is.
So if you run a speed test on the Internet connection and it's 8mbps, then you should stream at 1080P/29.97 with a bitrate of 4mbps.
Try that bitrate and see if it is stable. You may be able to go up to 5mbps, but do a long term test. If there are issues, go back down to 4mbps.
Here are recommendations for live encoder settings from YouTube:
https://support.google.c...ube/answer/2853702?hl=en
thanks 1 user thanked SportsNetUSA.net for this useful post.
AgentPete on 8/7/2019(UTC)
Guest (4)
