vMix crash when using "Settings" options
Hi
I have the issue with vMix - when i click left mouse button on the settings button, vmix freezes and crash. I've installed newest dot net and reinstalled vmix (10 and 11 version) and i still have same issue. Please advise something.
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
It's likely there is a bad codec installed on your system that is crashing vMix. To track it down, go the details of the crash error message and it should reveal a dll as the cause.
You can also find out the error by trying the following:
1. Go to start menu type Event Viewer and press enter 2. Open up Windows Logs section in left hand column and then go to Application 3. Find the Application Error entry in the list that mentions vMix and post the contents here.
Martin vMix
Here is info from Log Event:
2 user registry handles leaked from \Registry\User\S-1-5-21-777388950-876214254-
3914368145-1000_Classes: Process 1164 (\Device\HarddiskVolume2\Program Files (x86)\vMix\vMix.exe) has opened key
\REGISTRY\USER\S-1-5-21-777388950-876214254-3914368145-1000_CLASSES Process 1164 (\Device\HarddiskVolume2\Program Files (x86)\vMix\vMix.exe) has opened key
+ System
- Provider
[ Name] Microsoft-Windows-User Profiles Service [ Guid] {89B1E9F0-5AFF-44A6-9B44-0A07A7CE5845}
EventID 1530
Version 0
Level 3
Task 0
Opcode 0
Keywords 0x8000000000000000
- TimeCreated
[ SystemTime] 2013-11-07T12:16:03.399311900Z
EventRecordID 23903
Correlation
- Execution
[ ProcessID] 1040 [ ThreadID] 7520
Channel Application
Computer LIVE_EDIT
- Security
[ UserID] S-1-5-18
- EventData
Detail 2 user registry handles leaked from \Registry\User\S-1-5-21-777388950-
876214254-3914368145-1000_Classes: Process 1164 (\Device\HarddiskVolume2\Program Files
(x86)\vMix\vMix.exe) has opened key \REGISTRY\USER\S-1-5-21-777388950-876214254-
\vMix.exe) has opened key \REGISTRY\USER\S-1-5-21-777388950-876214254-3914368145-
1000_CLASSES
23 user registry handles leaked from \Registry\User\S-1-5-21-777388950-876214254-
3914368145-1000: Process 1164 (\Device\HarddiskVolume2\Program Files (x86)\vMix
\vMix.exe) has opened key \REGISTRY\USER\S-1-5-21-777388950-876214254-3914368145-1000
\REGISTRY\USER\S-1-5-21-777388950-876214254-3914368145-1000 Process 1164 (\Device
\HarddiskVolume2\Program Files (x86)\vMix\vMix.exe) has opened key \REGISTRY\USER\S-1-
5-21-777388950-876214254-3914368145-1000 Process 1164 (\Device\HarddiskVolume2\Program
Files (x86)\vMix\vMix.exe) has opened key \REGISTRY\USER\S-1-5-21-777388950-876214254-
3914368145-1000 Process 1164 (\Device\HarddiskVolume2\Program Files (x86)\vMix
\REGISTRY\USER\S-1-5-21-777388950-876214254-3914368145-1000 Process 708 (\Device
\HarddiskVolume2\Windows\System32\lsass.exe) has opened key \REGISTRY\USER\S-1-5-21-
777388950-876214254-3914368145-1000 Process 708 (\Device\HarddiskVolume2\Windows
\System32\lsass.exe) has opened key \REGISTRY\USER\S-1-5-21-777388950-876214254-
3914368145-1000 Process 708 (\Device\HarddiskVolume2\Windows\System32\lsass.exe) has
opened key \REGISTRY\USER\S-1-5-21-777388950-876214254-3914368145-1000\Software
\Microsoft\SystemCertificates\Disallowed Process 1164 (\Device\HarddiskVolume2\Program
3914368145-1000\Software\Microsoft\SystemCertificates\Disallowed Process 1164 (\Device
5-21-777388950-876214254-3914368145-1000\Software\Microsoft\SystemCertificates
\TrustedPeople Process 1164 (\Device\HarddiskVolume2\Program Files (x86)\vMix\vMix.exe)
has opened key \REGISTRY\USER\S-1-5-21-777388950-876214254-3914368145-1000\Software
\Microsoft\Windows\CurrentVersion\Explorer Process 1164 (\Device
5-21-777388950-876214254-3914368145-1000\Software\Policies\Microsoft\SystemCertificates
\REGISTRY\USER\S-1-5-21-777388950-876214254-3914368145-1000\Software\Microsoft\Direct3D
\REGISTRY\USER\S-1-5-21-777388950-876214254-3914368145-1000\Software\Microsoft\Windows
\CurrentVersion\Internet Settings\Connections Process 708 (\Device
777388950-876214254-3914368145-1000\Software\Microsoft\SystemCertificates\My Process
\SystemCertificates\My Process 1164 (\Device\HarddiskVolume2\Program Files (x86)\vMix
1000\Software\Microsoft\SystemCertificates\CA Process 708 (\Device
777388950-876214254-3914368145-1000\Software\Microsoft\SystemCertificates\CA Process
\SystemCertificates\Root Process 1164 (\Device\HarddiskVolume2\Program Files
3914368145-1000\Software\Microsoft\SystemCertificates\trust Process 1164 (\Device
5-21-777388950-876214254-3914368145-1000\Software\Microsoft\Windows NT\CurrentVersion
\SystemCertificates\SmartCardRoot
+ System
- Provider
[ Name] Application Hang
- EventID 1002
[ Qualifiers] 0
Level 2
Task 101
- TimeCreated
[ SystemTime] 2013-11-07T11:38:26.000000000Z
EventRecordID 23882
Channel Application
Computer LIVE_EDIT
Security
- EventData
vMix.exe 10.0.0.59 48c 01cedbad3567952f 60000 C:\Program Files (x86)\vMix\vMix.exe
55006E006B006E006F0077006E0000000000
I've got problem to paste full Event log, "There has been a serious error loading the forum. No further information is available." So please look up here: http://textuploader.com/dbfb
Is it a freeze or a crash that occurs? If it is a freeze you will need to go through your installed programs and uninstall any codecs to see if that helps.
Can you also confirm windows version, cpu and graphics card?
Martin vMix
