Hi All, I cannot add my HD camera in an version of Vmix. I keep getting this error message: INPUT_CAPTURE AddNewInput.INPUT_CAPTURE
CAn someone please help
Joined: 6/29/2011(UTC) Posts: 313   Location: Florida Thanks: 6 times Was thanked: 33 time(s) in 32 post(s)
Riculus, we need more information. you can start with what's the resolution selected, what frame rate are you choosing, what type of connection i.e. SDI, HDMI or Component. Oh and what capture card are you using?
Hi, Sorry for the lack of info. Just an update I got the video up and running. It was an error on my path. FYI. It is a HDMI connection using a Blackmagic Intensity pro card.
The sound on my stream in not synced with the video. How can I fix that?
Joined: 1/13/2010(UTC) Posts: 5,317  Location: Gold Coast, Australia Was thanked: 4719 time(s) in 1617 post(s)
Riculus wrote: The sound on my stream in not synced with the video. How can I fix that?
Can you provide some information about how you are streaming and where the audio/video sources are coming from? Also is the audio later than the video or before? Also, are you using the latest version of vMix? (11.0.0.62) http://www.vmix.com.au/download.aspxRegards, Martin vMix
Martin, I am Streaming on Ustream using FMLE. I'm using a Sony HD camera. I tried using the the Audio from the capture card, Sound card mic and line in and Vmix audio. The sound is ahead of the video, about 5 second. This is all from memory so I might be off a second with the sound.
Thanks, Riculus
Riculus wrote: I tried using the the Audio from the capture card, Sound card mic and line in and Vmix audio. The sound is ahead of the video, about 5 second. This is all from memory so I might be off a second with the sound.
Thanks, Riculus
It sounds to me your system may be a bit under powered. Try this , Go to windows control panel and open BlackMagic control then set input to HDMI with analog audio In vMix add the camera input selecting HDMI for input and select the same card as audio source Make sure to connect the audio inputs (Red&White audio inputs) on breakout cable to your audio source which I am assuming is a mixer. Then do two things, First record a sample of video with audio on your local hard drive and play it back to see if all is in sync. I don't know your system specs so record in a Mpeg (.mpg) format at 4 to 7 Mbps Second stream to your CDN and check sync. Viewing should be done on a different system either a desktop or laptop that's hard wired to Internet for best results. Also please list your system specs in reply. such as CPU, RAM, Video Card model, Number of hard drives, Motherboard model We need to know if your system meets requirements to help you. BR EdG
