elgarf
#1 Posted : Friday, July 26, 2019 7:15:56 PM(UTC)
elgarf
Russian Federation
Was thanked: 229 time(s) in 129 post(s)
In the latest vMix version display position coordinates fixed to 1280x720, instead of output size. Is this a bug or feature?
AlanZ
#2 Posted : Saturday, July 27, 2019 12:36:09 AM(UTC)
AlanZ
You should be able to change the numbers in the position section. Also, if I recall correctly, turning off the position checkbox let’s the full screen display use the entire screen. As a matter of curiosity, why would you want such a small output and fullscreen display size of 400x300?
elgarf
#3 Posted : Saturday, July 27, 2019 1:18:02 AM(UTC)
elgarf
Russian Federation
Yes, I can change them. But:
If I have FHD display, and set output resolution 1920x1080, I still limited 1280x720 coordinates.
For example, I need exact picture 840x504 in center of screen (no matter why). My monitor resolution is 1920x1080 (which I set in output size). So, I'll do some math, and get numbers:
X=(1920-840)/2=540,
Y=(1080-504)/2=288.
Width=840,
Height=504.
I'll write this numbers into position fields, aaaand... My picture is not at center, because position coordinates based on 1280x720 resolution.
400x300 is just for testing.
