Display position is fixed to 1280x720
Joined: 10/23/2015(UTC) Posts: 458   Thanks: 20 times Was thanked: 231 time(s) in 130 post(s)
Hello, In the latest vMix version display position coordinates fixed to 1280x720, instead of output size. Is this a bug or feature?  dpos.png (19kb) downloaded 2 time(s).
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
You should be able to change the numbers in the position section. Also, if I recall correctly, turning off the position checkbox let’s the full screen display use the entire screen. As a matter of curiosity, why would you want such a small output and fullscreen display size of 400x300?
Originally Posted by: AlanZ  You should be able to change the numbers in the position section. Yes, I can change them. But: If I have FHD display, and set output resolution 1920x1080, I still limited 1280x720 coordinates. For example, I need exact picture 840x504 in center of screen (no matter why). My monitor resolution is 1920x1080 (which I set in output size). So, I'll do some math, and get numbers: X=(1920-840)/2=540, Y=(1080-504)/2=288. Width=840, Height=504. I'll write this numbers into position fields, aaaand... My picture is not at center, because position coordinates based on 1280x720 resolution. 400x300 is just for testing.
