Joined: 3/8/2016(UTC) Posts: 123 Location: Anniston, Alabama
I am trying to create a countdown to a specific date/time from within vMix. I do not code, and I believe this requires xaml capabilities, which I don't have. That gave me the idea that someone might be able to create a plugin or converter that would allow the user to tell it what point in time they want a countdown to, then the plugin would create the xaml code to use in vMix In my case, I'm trying to create a countdown in Days:hours:minutes:seconds to 7 pm on August 25th, to promote when we begin our high school football coverage.
Hi Jim why don't you simply use a countdown script that we can find on the web. Most of them are very easy to use and integrate into vMix like any other webpage via the webbrowser input. For example: https://countingdownto.c...-s-event-countdown-clockthat you can edit to your needs from the actions button on the left. Just unpublish, edit and re-publish or https://www.w3schools.co...name=tryhow_js_countdownjust have to enter the date and time you wish, run the example code. When satisfied, copy and paste the left code to a text file that you name countdown.html anywhere on your computer. Opening this file in a browser will show your countdown. Hope this helps Guillaume
Joined: 12/20/2016(UTC) Posts: 191   Location: Milano Was thanked: 21 time(s) in 13 post(s)
I think to have understood that this feauture will be in vmix 20.
Hi Lino
I think vMix 2x will integrate 2 production clocks in the UI, not really what Jim's talking about here.
Guillaume
Ok, maybe I didn't understood what Jim needs.
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
Jim,
This is the code I've found to do it in vMIx:
{0:7 July 2017 12:00 AM|HH:mm:ss}
Kind regards, Rudy
 1 user thanked rudyengels for this useful post.
Thanks: 211 times Was thanked: 13 time(s) in 12 post(s)
Good find Rudy, appreciate the post
