66 Pages«<3536373839>»
JAIRODJ
#721 Posted : Friday, June 21, 2019 6:26:13 AM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
I have to think about certain issues with the clock.
There is a situation in the clock widgets.
1- On some days it is deactivated some marked days (it only seems to be a bug).
2.- If you add clocks with different hours, it does not take the current time but the one in the order that was added.
Ex:
Currently it is like this.
CURRENT TIME 14H30
ADDED WATCHES
1-20h00
2-15h30
3-14H50
NEXT EVENT 20H00
I should take the event closest to the current time.
Perhaps it is necessary to add buttons to move the clocks (up - down) that allow chronological ordering ... or that are added neatly and automatically according to the added time.
elgarf
#722 Posted : Friday, June 21, 2019 11:54:06 PM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
@JAIRODJ, that's strange, because UTC sort events automatically after properties saving.
Can you share controller with skipped events?
JAIRODJ
#723 Posted : Saturday, June 22, 2019 2:06:09 AM(UTC)
JAIRODJ
This project was created with version 16-04-2019, I have updated to 06-17-2019, the problem continues.
I have added an additional clock at the end (18h50) and it remains there, it is not ordered.
I opened the project on another PC and the same problem persists.
Attention
When creating a new project in version 17-06, if it is automatically ordered.
CLOCKS PROJECT
<< Additional >>
Well me and my ideas, if it is possible to make them come true (apologies if annoying, they are ideas not demands).
1- When a UTC saved project is opened that automatically activates a specific widget.
2- When blocking with a key, all UTC is blocked. If I need to make a quick change,
everything must be unlocked again. Then it will be possible to lock with a key only
the widget that activates the lock and that the others are free and can be modified quickly.
(blocking is really good, projects are not damaged by bad manipulation of another user, but changes are required in certain widgets).
elgarf
#724 Posted : Saturday, June 22, 2019 4:00:21 AM(UTC)
elgarf
Russian Federation
@JAIRODJ, looks like time info was with date info, so it order events, but you've added them not at the same day, so I made ordering not so date specific.
I've also added some code, so UTC must fire event if it scheduled.
Try this:
Download
1) I can make autostart checkbox into button properties, why not.
2) I thought blocking with key if for distributing controller, so you not need to make changes. That's why I blocked all lock/unlock buttons.
JAIRODJ
#725 Posted : Tuesday, June 25, 2019 2:27:09 AM(UTC)
JAIRODJ
Hi, thanks @elgarf, if the clock works perfectly with the new update.
With respect to the button or option of automatic start of a widget:
With the function of exelink, you can activate any widget, then if you
can only add the option that activates a particular one, it will be enough
to activate N number of widgets with a single button, avoid adding the start
option to each button. Well, I believe in ideas, in logic I do not know.
With the controller lock.
The station in which I work accepts intern students and they curiously
change the UTC settings, for that reason I thought about blocking UTC,
but leaving some widgets so that they can update their
needs (For example: Textfield, Overlays, etc.) .. they have knowledge to use code.
Well I have learned a bit of code with UTC to get a better performance
(reading read reading hours and hours on code to understand), but it has been very helpful for me.
elgarf
#726 Posted : Wednesday, June 26, 2019 1:11:09 AM(UTC)
elgarf
Russian Federation
@JAIRODJ, I think I found good solution for both your requests, wait till next update.
elgarf
#727 Posted : Tuesday, July 2, 2019 5:31:30 PM(UTC)
elgarf
Russian Federation
New version with Clock widget fixes & JAIRODJ requests.
For making some widgets to not lock completely with password, uncheck "Password Lockable" checkbox in widget context menu.
Universal Title Controller
thanks 1 user thanked elgarf for this useful post.
kevev on 7/7/2019(UTC)
JAIRODJ
#728 Posted : Wednesday, July 3, 2019 7:56:54 AM(UTC)
JAIRODJ
Thanks for the help. @elgarf
As it is said in my country:
"This exquisite" = that is perfect
thanks 1 user thanked JAIRODJ for this useful post.
elgarf on 7/3/2019(UTC)
chococrispis35
#729 Posted : Tuesday, July 23, 2019 5:10:43 AM(UTC)
chococrispis35
Stream Deck EL GATO works with UTC?
郭子涵
#730 Posted : Saturday, September 7, 2019 10:49:56 PM(UTC)
郭子涵
China
Thanks!
Very nice,I want to control TitleBeginAnimation and control page1 or page2 ... ...How to do ?
comporder1
#731 Posted : Thursday, September 12, 2019 5:54:54 AM(UTC)
comporder1
Views messages in topic : 24
Originally Posted by: 郭子涵 Go to Quoted Post
Thanks!
I had to learn how to do this myself. Add this to functions.xml in the "<Function>Title Controls</Function>" group.
<vMixFunctionReference>
<Description>Set GT Title Page number</Description>
<Function>TitleBeginAnimation Page1</Function>
<FormatString>Function=TitleBeginAnimation&amp;Input={0}&amp;Value=Page1</FormatString>
</vMixFunctionReference>
<Function>TitleBeginAnimation Page2</Function>
<FormatString>Function=TitleBeginAnimation&amp;Input={0}&amp;Value=Page2</FormatString>
<Function>TitleBeginAnimation Page3</Function>
<FormatString>Function=TitleBeginAnimation&amp;Input={0}&amp;Value=Page3</FormatString>
<Function>TitleBeginAnimation Page4</Function>
<FormatString>Function=TitleBeginAnimation&amp;Input={0}&amp;Value=Page4</FormatString>
<Function>TitleBeginAnimation Page5</Function>
<FormatString>Function=TitleBeginAnimation&amp;Input={0}&amp;Value=Page5</FormatString>
<Function>TitleBeginAnimation Page6</Function>
<FormatString>Function=TitleBeginAnimation&amp;Input={0}&amp;Value=Page6</FormatString>
<Function>TitleBeginAnimation Page7</Function>
<FormatString>Function=TitleBeginAnimation&amp;Input={0}&amp;Value=Page7</FormatString>
<Function>TitleBeginAnimation Page8</Function>
<FormatString>Function=TitleBeginAnimation&amp;Input={0}&amp;Value=Page8</FormatString>
<Function>TitleBeginAnimation Page9</Function>
<FormatString>Function=TitleBeginAnimation&amp;Input={0}&amp;Value=Page9</FormatString>
<Function>TitleBeginAnimation Page10</Function>
<FormatString>Function=TitleBeginAnimation&amp;Input={0}&amp;Value=Page10</FormatString>
thanks 1 user thanked comporder1 for this useful post.
郭子涵 on 9/12/2019(UTC)
郭子涵
#732 Posted : Thursday, September 12, 2019 11:19:15 PM(UTC)
郭子涵
China
Thanks a lot ,My problem was fixed.
guard thanks again!
郭子涵
#733 Posted : Thursday, September 12, 2019 11:21:39 PM(UTC)
郭子涵
China
Thanks!
Guard thanks again!
comporder1
#734 Posted : Saturday, September 14, 2019 4:36:43 AM(UTC)
comporder1
guard thanks again!
Glad I could help.
MickeyMJJ
#735 Posted : Thursday, September 19, 2019 7:31:13 AM(UTC)
MickeyMJJ
Is it possible to change the attributes of a text in a title (for example the size of the font)?
MickeyMJJ
#736 Posted : Wednesday, October 2, 2019 3:10:58 AM(UTC)
MickeyMJJ
Originally Posted by: MickeyMJJ Go to Quoted Post
no one has the answer?
elgarf
#737 Posted : Friday, October 4, 2019 2:45:10 AM(UTC)
elgarf
Russian Federation
@MickeyMJJ, looks like it's not possible from API, but you can do a lot of things with XAML titles because of bindings.
Here is example.
NewsHD.xaml (3kb) downloaded 19 time(s).
Btw, there are small changes into UTC.
Into the new version:
Fix of expression calculating into INDEX parameter of script function, and new [Slider] widget to control input/master/bus volume.
郭子涵
#738 Posted : Friday, October 4, 2019 11:03:37 PM(UTC)
郭子涵
China
Hi,Can I control "colour key"?
chococrispis35
#739 Posted : Saturday, October 5, 2019 12:36:36 AM(UTC)
chococrispis35
Elgarf, yesterday replaced utc with the new version with slider volume control, but I had problems having the active signal with sound.
when changing the title to the next line (data source next row) on excel document, the sound goes down to zero, every time I jump to the next title next row the slide lowers the volume to zero.
elgarf
#740 Posted : Saturday, October 5, 2019 12:58:01 AM(UTC)
elgarf
Russian Federation
@chococrisps35, hmm, I'll check this.
Guest (10)
