Hardware Compatibility
spec for 8 input 2x quad system
Our system is pretty much the recommended system for a 2 x quad system, but if we have more than 6 inputs, the inputs start blinking. Here is our spec: Motherboard: Asus Tek Z170-AR LGA1151 Graphics Card: Geforce GTX 1060 6Gb Capture Card: Blackmagic quads x 2 Processor 17 7700 3.6 GHz, Kaby Lake 14nn tech Ram: 16GB Dual Channel @ 1070 Mhz windows 10 Here is the recommendation: https://www.vmix.com/pro...erence-systems.aspx#rubyMotherboard: Gigabyte Z370 AORUS Gaming 5 or Gigabyte Z370 AORUS Gaming 7 (Intel Z370) Graphics Card: NVIDIA GeForce GTX 1060 Capture Card: AJA Corvid 88 or Blackmagic Decklink Quad 2 - we use 2 x quads CPU: Intel Core i7 9700K 3.6GHz+ RAM: 16GB (2x8GB) DDR4 Operating System: Windows 10 Any help/suggestions much appreciated, Thanks, Alan Costello
Joined: 3/7/2012(UTC) Posts: 2,679  Location: Canada Thanks: 33 times Was thanked: 512 time(s) in 480 post(s)
@ antardwip
Methinks you have run out of lanes! The Blackmagic Decklink Quad 2 is a x8 PCIe card So the Z370 has 24 lanes but the i7 7700 CPU only allows for 16 and so can handle a GPU and one Quad (x8/x8) but not a second Quad as the slot would render the slots as x8/x4+x4. If wanting to use more than one multichannel capture card, it is recommended to use an X299 MB with an appropriate CPU (Obsidian build).
Thank you for that Ice, very good of you to help - we have 2 x 4 input quads, not the 2 x8 input quads. That is a total of 8 inputs. The Motherboard I am using has dual x8 mode; single card: x16 mode, x4 mode (Type CPU, DIMM 288-pin, PCI, PCIe 3.0 x1, PCIe 3.0 x16) But I don't know how many lanes that is. You say more than 1 mulitchannel card needs x299 with obsidian CPU - is that the same whether they are 4 input quads or 8 input quads? Thanks again, Antardwip
