3 Pages<123>
Bardos
#21 Posted : Tuesday, November 5, 2013 11:23:10 PM(UTC)
Bardos
Groups: Guests
vedranius: This guy Martin listens to his customers, and keeps trying to make his program better...He is very understanding and always improving his stuff....
I have one thing to say though...I wish his program had a more traditional look, like Tricaster, AVTake, and similar, with the user being able to rearrange the GUI to his or her style and being able to remove the preview monitor, since it can still be viewed on the multiview output........but it rocks...I have two friends who I work with, and they have me hooked on it....and now with this new improvement, I will be calling on them to upgrade as soon as possible....
Great work Martin...keep it going..
thanks 2 users thanked Bardos for this useful post.
vedranius on 11/6/2013(UTC), Ernest Król on 11/6/2013(UTC)
#22 Posted : Wednesday, November 6, 2013 5:27:09 AM(UTC)
vMix 11.0.0.60 has been released.
It includes the following changes/fixes:
* The clear button under the Stream input tab was not refreshing the list.
* Large audio delays were not working on DeckLink output.
* Virtual Input will will correctly reload from Preset even if it is located before the source input.
* Reloading an Input now re-applies itself to any MultiView destinations
* All supported sizes are now selectable from capture input (such as 640x360) however most capture cards do not support them.
* Using the List input in a PlayList more than once was playing the same video each time instead of moving to the next item.
http://www.vmix.com.au/download/vmix11.exe
madness on 11/7/2013(UTC)
jet
#23 Posted : Wednesday, November 6, 2013 11:18:29 AM(UTC)
jet
Was thanked: 39 time(s) in 37 post(s)
Hi Martin!
The version that is currently online is 11.0.0.58 and the text on the download page says it's 11.0.0.41.
Kind regards,
Jan Tervo
#24 Posted : Wednesday, November 6, 2013 11:20:28 AM(UTC)
The link above should take you to the latest version.
The web site download page uses a CDN, so it will take around 24 hours to update.
niklasforssen
#25 Posted : Thursday, November 7, 2013 9:00:06 AM(UTC)
niklasforssen
Hello, great work!
But I have a problem on our first rig, i7 3930, Gtx 560 Ti, Win7Pro Latest windows update, and latest nvidia driver.
The problem is when i jumped from 11.0.0.34 to 11.0.0.58 and 60, I no longer see the "Layout window", when i doubleclick a source to move it or adjust it, the window shows controls but the video window is black.
I'm also building a new rig, almost the same specs, but a 4820 and a GTX760 instead, and voila, both 11.0.058 and 11.0.0.60 works great, what could be the issue?
#26 Posted : Thursday, November 7, 2013 9:47:16 AM(UTC)
Thanks for the report.
You can download vMix 11.0.0.62 below:
This fixes the blank preview in Input Settings when using the Windows 7 "Basic" theme.
madness on 11/7/2013(UTC), niklasforssen on 11/7/2013(UTC)
niklasforssen
#27 Posted : Thursday, November 7, 2013 10:50:21 AM(UTC)
niklasforssen
Best support ever.
Thank you.
/Niklas
wwdv
#28 Posted : Saturday, November 9, 2013 3:24:43 PM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
The settings menu in version 11.0.0.62 is not responding for a while when the items web, Tally lights, shortcuts and about are selected.
The other items are responding okay.
Version 11.0.0.41 is okay.
#29 Posted : Saturday, November 9, 2013 9:27:22 PM(UTC)
wwdv
#30 Posted : Sunday, November 10, 2013 7:37:47 PM(UTC)
wwdv
admin wrote:
Please try 11.0.0.63 below:
This version is OK.
Thanks.
watchfulone
#31 Posted : Wednesday, December 11, 2013 12:46:46 PM(UTC)
watchfulone
Was thanked: 17 time(s) in 14 post(s)
admin wrote:
Can't wait for Version 12 with all it's goodies.
jet
#32 Posted : Saturday, December 21, 2013 2:19:06 PM(UTC)
jet
watchfulone wrote:
When will v12 beta be released?
Kind regards,
J. Tervo
thanks 1 user thanked jet for this useful post.
Adriankey4 on 12/25/2013(UTC)
jet
#33 Posted : Saturday, December 28, 2013 3:51:13 PM(UTC)
jet
jet wrote:
soundsinvision wrote:
jet - did you get the Intensity Pro working reliably with your installation? I was looking at getting one to use with a PC I'm planning, but also wondered if you can have the analog and HDMI inputs as separate sources with that card (or even the USB3 Intensity Shuttle).
Right now I can't justify $1000-ish for the Magewell equivalent card.
Hi.
vMix 11.0.0.41 has so far worked without that Intensity Pro initialize problem.
Kind regards,
J. Tervo
Hello Martin.
vMix Intensity Pro initialize problem is still there.
I have the latest vMix 11.0.0.63 and Intensity Pro initialize problem still occurs every now and then.
If the problem occurs and I then run Media Experss and restart vMix then Intensity Pro initializes correctly.
Kind regards,
J. Tervo
#34 Posted : Saturday, December 28, 2013 9:47:10 PM(UTC)
Hi Jet,
Make sure you are selecting the correct connection type from the Input dropdown box.
(HDMI, Component etc)
If you leave this at default it may not always select the correct input.
jet
#35 Posted : Sunday, December 29, 2013 6:26:07 AM(UTC)
jet
admin wrote:
Hi Jet,
Hello Martin.
This happens (also) with saved presets. Just dark gray box is displayed in the container.
Kind regards,
J. Tervo
asvtv
#36 Posted : Sunday, December 29, 2013 7:12:46 AM(UTC)
asvtv
jet wrote:
admin wrote:
Hi Jet,
Hello Martin.
Kind regards,
J. Tervo
We had the same issue. Just verify all your setup resolution (camera, input, program, etc ...)
#37 Posted : Sunday, December 29, 2013 9:50:08 AM(UTC)
This can happen if the capture was setup with Input set to "Default".
If you select the input type such as HDMI etc and then save the preset it should work fine.
jet
#38 Posted : Monday, December 30, 2013 12:08:44 PM(UTC)
jet
Hello!
The input was set as Component and video format as Default.
#39 Posted : Saturday, January 4, 2014 2:56:36 AM(UTC)
A small update to vMix 11 has been released (11.0.0.64)
Fixes:
* Direct3D error under Windows 8/8.1 has been fixed, the Direct3D9 runtime no longer needs to be installed.
* Fixed audio delay after long periods of time on the Decklink External Output
* Now supports scaled displays 150% and greater
melody
#40 Posted : Saturday, January 4, 2014 7:09:07 AM(UTC)
Rank: Guest
Groups: Guests
hi martin,
such a good news... nice job.
regards,
melody
www.espiritosanto.cc
Guest (13)
3 Pages<123>
