Can't Advance PowerPoint Slides Manually
Rank:: Newbie
Joined: 6/13/2019(UTC) Posts: 2 Location: Alexandria, Virginia US Thanks: 1 times
I have added a .pptx file from my hard drive as an input to a vMix project. I want to advance the slides in the deck manually as I give my webinar. For some reason vMix starts playing the deck automatically whenever I transition to it, either as its own input or any input that includes it as a layer. As near as I can tell, I have everything set correctly (see image below). Please tell me what I'm doing wrong. I really need this feature to work correctly for me. Thanks very much, Frank
Joined: 8/24/2016(UTC) Posts: 19 Location: Olive Branch, MS
Thanks: 4 times Was thanked: 5 time(s) in 5 post(s)
Place your cursor on the powerpoint module, right click, open "slide show settings". Change the transition setting to "0" that should do it.
1 user thanked samrikard for this useful post.
Rank:: Newbie
Thanks very much Sam! That has fixed my problem and made my stream today possible. I appreciate your help very much. Frank
Joined: 2/26/2017(UTC) Posts: 6 Location: Corunna, MI
This is one feature that could be improved upon incredibly.
