fdooman
#1 Posted : Thursday, June 13, 2019 2:39:14 PM(UTC)
fdooman
Just updated VLC 3.0.6 player to 3.0.7.1. everything went south. Not compatible with NDI tools 3.8. Went back to 3.0.6. everything works now. This is just a heads up for those who want to try it.
Fred
kane
#2 Posted : Sunday, June 16, 2019 6:06:43 AM(UTC)
kane
Fred
If you copy out 'libndi_plugin.dll' from 'C:\Program Files\VideoLAN\VLC\plugins\video_output' from VLC 3.06, then do the VLC upgrade and copy this DLL file back in the same location, it will work. Looks like the VLC upgrade can wipe-out the NDI plug-in and the NDI Tools installer isn't able to recognize the VLC 3.0.7.1 software to install the plug-in again.
I'm going to bug it, but the above should get you work for the time being.
Kane Peterson
NewTek
fdooman
#3 Posted : Sunday, June 16, 2019 5:48:29 PM(UTC)
fdooman
Thanks a bunch Kane, will try that.
Fred
slb5146
#4 Posted : Saturday, July 6, 2019 12:34:54 PM(UTC)
slb5146
You have been a member since:: 8/31/2016(UTC)
Thank you Kane. You saved the day for me.
Steve Brown
spino
#5 Posted : Sunday, July 7, 2019 6:48:09 PM(UTC)
spino
Italy
Was thanked: 21 time(s) in 13 post(s)
The problem of new vlc versions is that video output to NDI works but we can't load in a playlist still images (jpeg) to send over NDI output. In old versions this was possible.
Guest (4)
