NDI
New VLC 3.0.7.1
Joined: 6/16/2018(UTC) Posts: 30 Location: LOS ANGELES
Just updated VLC 3.0.6 player to 3.0.7.1. everything went south. Not compatible with NDI tools 3.8. Went back to 3.0.6. everything works now. This is just a heads up for those who want to try it.
Fred
Originally Posted by: fdooman  Just updated VLC 3.0.6 player to 3.0.7.1. everything went south. Not compatible with NDI tools 3.8. Went back to 3.0.6. everything works now. This is just a heads up for those who want to try it.
Fred If you copy out 'libndi_plugin.dll' from 'C:\Program Files\VideoLAN\VLC\plugins\video_output' from VLC 3.06, then do the VLC upgrade and copy this DLL file back in the same location, it will work. Looks like the VLC upgrade can wipe-out the NDI plug-in and the NDI Tools installer isn't able to recognize the VLC 3.0.7.1 software to install the plug-in again. I'm going to bug it, but the above should get you work for the time being. Kane Peterson NewTek
Thanks a bunch Kane, will try that. Fred
Joined: 8/31/2016(UTC) Posts: 15   Location: Little Rock, AR Thanks: 4 times
Thank you Kane. You saved the day for me. Steve Brown
Joined: 12/20/2016(UTC) Posts: 191   Location: Milano Was thanked: 21 time(s) in 13 post(s)
The problem of new vlc versions is that video output to NDI works but we can't load in a playlist still images (jpeg) to send over NDI output. In old versions this was possible.
NDI
New VLC 3.0.7.1
