Hello Iam planning live streaming lotto draws .I need to display on Title bar each lotto ball as they are drawn and at the end all the 5 numbbers( 5 balls) that were drawn Please how can i get a title bar for lotto draws to use RGD Frank
Joined: 8/8/2017(UTC) Posts: 17 Location: Los Angeles
There are a few ways to accomplish what you're trying to do. They all start with either using a pre-built graphic or designing one and importing it into the GT Title Designer. From there, it becomes about filling out the fields to have them appear when you want them to. Pre-built option can be found using Add Input -> Title / XAML. GT Title Designer option for more custom designed graphics: Getting started with GT Title DesignerThe next step is to find a way to change the data within the template live. There are a few ways I know of to approach this. The first is to use a Google Spreadsheet with Data Sources. Google Configuration: https://www.vmix.com/hel...ex.htm?GoogleAPIKey.htmlData Source Mapping: https://www.vmix.com/hel...SourcesTitleMapping.htmlMartin Walking Through Data Source Mapping: Another simple and free way to go is to use vMixUTC. This would involve creating a graphic within the GT Title Designer, and then using the dashboard within the UTC to control the graphics to playout as needed. It's a really impressive way to control graphics. https://forums.vmix.com/...iversal-Title-ControllerFinally, if you want someone else from another computer on the network to control the graphics, you can have them do so from the web interface. -Elliot
