Overlaying transparent PNG text slides
Thanks: 30 times Was thanked: 1 time(s) in 1 post(s)
Probably a simple thing, but I'm a bit rusty on Vmix. Can anyone help? I want to overlay a series of PNG text files (with transparent background) for a worship song. I have about 40 of these slides. I've created a background image that combines a video and a static coloured image. This stays in the background as I change the slides.
I can't figure out how to have each slide appear ON TOP of the background video, except hitting the overlay button on each slide. I want to programme it as a playlist to get the timing perfect.
What should my approach be, the simplest way to do this? I suppose I could create a multiview input, then duplicate it 40 times, and go in, changing the top layer of each multiview. This seems a rather silly approach though?
Help a brain-fried brother out?
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 320 times Was thanked: 263 time(s) in 233 post(s)
Use multiview to put the PNG over the background for each shot. Then assemble the shots into a playlist. No way to time them all precisely, so use manual advance and follow the song as it plays.
Just figuring it out now - that multiview method maybe seems a little convoluted, unless I misunderstand.
What I've come up with is a key command for overlay 1. Then I just import all the PNG images, in numbered order, and click the image input, tap the 1 key, and it appears as an overlay. Then I click the next image to prep it, and tap 1 when I want that to replace the previous slide as the new overlay. If I want no slide, I have set Q key to be the remove all overlays function.
