GT
Separating text on a line into vmix
Hi all,
I'd like to know if anyone has a way to separate and isolate text between delimiters or other dividing factors for use as individual elements in a graphic. What I can get in is this.
Keith Roberts;209;34;18:46:13<CR><LF>
However I'm looking for a way of separating these to work as different elements of text.
Keith Roberts (text box 1) 209 (text box 2) 34 (text box 3) 18:46:13 (text box 4)
Does anyone know a way of doing this? I'd like to use a method of this for data that is coming in live.
Joined: 12/27/2012(UTC) Posts: 5,504  Location: Belgium Thanks: 314 times Was thanked: 1020 time(s) in 838 post(s)
Thanks for getting back.
How do I separate different elements on the same line of text though? I've checked around data sources and I can't see anything that might be able to do it apart from 'format' and I've only ever seen that used to add things to an existing line, not select a part of a line of text.
a lot depends on where your data is coming from
at best as CSV ( but separated by commas instead)
Then there are tons of tutorial videos on how to use the data source into title text fields
Joined: 11/19/2013(UTC) Posts: 129 Location: Hobart Tasmania Australia
Thanks: 13 times Was thanked: 11 time(s) in 8 post(s)
GT
