SethQTV
#1 Posted : Tuesday, June 18, 2019 9:29:32 PM(UTC)
SethQTV
Hi all,
I'd like to know if anyone has a way to separate and isolate text between delimiters or other dividing factors for use as individual elements in a graphic.
What I can get in is this.
Keith Roberts;209;34;18:46:13<CR><LF>
However I'm looking for a way of separating these to work as different elements of text.
Keith Roberts (text box 1)
209 (text box 2)
34 (text box 3)
18:46:13 (text box 4)
Does anyone know a way of doing this? I'd like to use a method of this for data that is coming in live.
#2 Posted : Tuesday, June 18, 2019 9:36:28 PM(UTC)
Data Sources
SethQTV
#3 Posted : Tuesday, June 18, 2019 9:56:36 PM(UTC)
SethQTV
Thanks for getting back.
How do I separate different elements on the same line of text though?
I've checked around data sources and I can't see anything that might be able to do it apart from 'format' and I've only ever seen that used to add things to an existing line, not select a part of a line of text.
#4 Posted : Tuesday, June 18, 2019 10:10:39 PM(UTC)
a lot depends on where your data is coming from
at best as CSV ( but separated by commas instead)
Then there are tons of tutorial videos on how to use the data source into title text fields
Ash
#5 Posted : Wednesday, June 19, 2019 7:53:49 AM(UTC)
Ash
Was thanked: 11 time(s) in 8 post(s)
