Feature Requests
programming camera cuts to cue points on a music track.
Thanks: 9 times Was thanked: 3 time(s) in 3 post(s)
Hi I’d love a way to pre program camera cuts to a music track by cue points or using smpte timecode . It would be great for formatting shows and doing detailed work for music acts cut to the beat . Is any body else interested in this kind of functionality ? Imagine also if your camera operators could see the shot list on the tally and hear a preprogrammed audio cue . "Coming to camera 2" etc
Joined: 5/14/2013(UTC) Posts: 155  Location: uk Thanks: 2 times Was thanked: 28 time(s) in 24 post(s)
in theory, you could just use a DAW like reaper playing the audio or slaved to external timecode and send MIdi notes to Vmix from a MIDI track , you could use a midi controller patched threw your daw to program and record the midi track
cheers
ian
That’s a good solution Henry for programmed camera cuts for sure,thanks. . I already use cubase to send smpte to lighting software so I can hopefully just send the midi back to Vmix as well . Regards Cormac
Feature Requests
