AgentPete
#1 Posted : Sunday, June 16, 2019 7:29:49 AM(UTC)
AgentPete
Was thanked: 9 time(s) in 3 post(s)
I’ve just started to use a Launchpad Mini Mk2 as a controller, and find that any transition apart from a straight “cut” is quite jittery, i.e. not smooth.
Also, trying to export the list of activators fails – it only exports a list of default MIDI devices, none of the events themselves.
Wonder if anyone can shed any light, please?
AgentPete
#2 Posted : Sunday, June 16, 2019 9:55:28 PM(UTC)
AgentPete
And here's an example...
#3 Posted : Monday, June 17, 2019 12:26:56 AM(UTC)
@ AgentPete
It has to do with the "value" of the button press.
The Launchpad essentially has two values for each button UP (0) and DOWN (127)
If you set the button "value" to 127 (Down position), you will eliminate this "double click" effect of the default 0 (Up position).
AgentPete on 6/17/2019(UTC)
AgentPete
#4 Posted : Monday, June 17, 2019 3:29:27 AM(UTC)
AgentPete
Brilliant! Problem solved - thanks, Ice!
